car cranks but wont start
Old Nov 10, 2005 | 06:10 PM
kingman109's Avatar
well - nother problem-
car ran fine after cam install - turned out alternator went bad and car died- so i got new alternator and charged the battery but she wont start now.
when i turn key fuel pump is turning on - but when i try and start her she'll crank and u'll hear the car try and start twice then crank- then try and start- and just keep doing the same - but wont actually start
checked and everything is hooked up, and only thing i had changed since it last ran was the alternator.
Old Nov 10, 2005 | 09:44 PM
Guest47904's Avatar
Guest
Re: car cranks but wont start
Got fuel pressure?
Old Nov 11, 2005 | 07:28 AM
MyShibbyZ28's Avatar
1) check fuel pressure
2) check fuel pressure regulator
3) Injectors??? Might as well check them too, but i doubt it's that
4) good luck
Did you have to take anything else off to get the alternator off? Maybe something else could have been damaged in the process. Who knows.
ShibbyZ
Old Nov 11, 2005 | 08:40 AM
kingman109's Avatar
well - im at work right now and wont get a chance to check things out till tommorow-
but i have good fuel pressure , checked that before i left-
which leaves either spark or battery, this may seem dumb but would it be possible for the battery to not be good enough to turn it over? i mean it cranks and tries but wont fire... any chance the battery is just bad on some level?
cause car started fine before- i changed out alternator after battery had died and i kept jumping it. in changing alternator only thing touched were the bolts on it and the plug- and theres really nothing near it i could have damaged that would be causing this problem. and the alternator itself just charges battery so car should still start off battery alone.
Old Nov 11, 2005 | 09:09 AM
Rage's Avatar
The battery is not the problem. You are correct, if the car is turning over than the battery is doing its job. You say your getting fuel, the engine obviously has compression, it's turning over but not starting, I'd say your getting no spark to the plugs. Im not too familiar with the opti-spark yet, but Im assuming if its bad then it's not delivering spark. So, my guess is going to be opti-spark.
Old Nov 12, 2005 | 09:00 AM
Bill_Mitchell's Avatar
Check opti spark and water pump. It's the first place to start.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
Lions3
Apr 11, 2003 10:55 AM
