Cap off oil cooler outlet from water pump
Old Jul 17, 2004 | 02:30 PM
southern78's Avatar
Is there a way other than buying a rubbing cap to plug the outlet coming from the water pump for the oil cooler? I running without a oil cooler.
Old Jul 17, 2004 | 02:38 PM
Mtrhds94Z's Avatar
There's a 'bypass' hose that runs from WP to Radiator when you don't have an oil cooler..
I can look the p/n up later.. not at home right now..
Old Jul 17, 2004 | 04:09 PM
Alex94TAGT's Avatar
Like Mtrhds94Z just said, there's a bypass hose that routes from the waterpump to the bottom driver's side of the radiator. GM part number 10197675.
Any auto parts store should carry it. Just ask for the lower radiator return hose for a *non-oil cooler equipped vehicle. The hose itself is roughly 1-1/4" in diameter, so if they give you something larger, you'll know it's the wrong one. It should be relatively skinny...
Old Jul 17, 2004 | 04:58 PM
southern78's Avatar
Its in my s10 blazer running with a corvette radiator that doesn't have a lower return inlet on the radiator
Old Jul 17, 2004 | 06:42 PM
Mtrhds94Z's Avatar
OK then cap it for now, and if you ever change the pump, get a Corvette pump [they don't have that 'bypass' hose 3rd fitting..]
Old Jul 18, 2004 | 08:53 AM
slmdgmc's Avatar
When I had my waterpump out of my truck to do some work on the timing cover and install an electric waterpump I solved this problem.
I blocked off the oil cooler outlet and both heater core ports on the radiator. I popped out the outlet necks, and tapped the waterpump for pipe threads. I believe 1/2 was used for the smaller ones, and 3/4 was the larger one. Then I inserted a threaded pipe cap into the new holes I made with some RTV on the threads. No leaks since, looks pretty nice (alot better than rubber caps and a loop for the heater hoses).
Old Jul 18, 2004 | 11:06 AM
Didn't we talk about doing that, once upon a time? Anyway, glad you posted that solution and that it works.
Visual water pump comparison. You can see that the bypass port is blocked on the non f-body pumps. The hose pipes are slightly different as well.
HectorM52
Jul 30, 2017 11:46 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
