Canton pan resting on K-member causing false knock?
Old Jul 30, 2005 | 08:41 PM
Gripenfelter's Avatar
I have an aftermarket K-member and the Canton pan rests on the power steering and K-member. My headers also touch the K-member.
Could this cause false knock? Any idea on how to get rid of it?
Old Jul 30, 2005 | 09:15 PM
NVetro's Avatar
Re: Canton pan resting on K-member causing false knock?
to my knowledge any strong vibration, espeically header vibrations can cause false knock. I think some have reported that they have had the same issues with exhausts causing false knock, some even said solid motor mounts sometimes do also, but not many have chimed in with that. But that could def be an issue....
Old Jul 30, 2005 | 10:43 PM
1racerdude's Avatar
ANY noise will pull timing.
Get 6 thick torque flat washers(3 to the side under each bolt) and put them between the block and motor mount.It will bring the engine up about 1/8".
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Nostang 96z
Sep 10, 2002 08:54 PM
