I just go tmy motor done and i cant get the pan to quit leaking from the drain plug. i tried the copper gasget and a different rubber gasket and they both leak a lot when the oil is warm. Has anyone else had this problem or what can i do to fix it?
Scott
Scott
check above the oil drain plug. on top of the passenger kick out there is a plug that leaks like a siv, and runs down the pan. Do a search, there was a recent post about it.
