Canton Oil Pan with BMR K Member
Old Oct 27, 2006 | 08:10 PM
93 4mula's Avatar
Will the Canton Oil pan Part #15-242T work with an aftermarket bmr k member? Also is there enough clearance in the pan for a 383?
Old Oct 27, 2006 | 08:30 PM
CALL911's Avatar
I have a 6 qt Canton Oil Pan (not sure of the part #) in my 383 car, and I also have the BMR K member as well as the upper and lower A-arms. Everything fit just fine in my car.
Old Oct 27, 2006 | 08:41 PM
oneslowz28's Avatar
yes it will fit.
Old Oct 27, 2006 | 08:43 PM
93 4mula's Avatar
I have done some reading and it seems even with that oil pan and a 383 stroker kit that the rods still hit the pan? I have the 5.7 rods do you think I will still have to clearance the pan?
Old Oct 27, 2006 | 08:46 PM
CANTONRACER's Avatar
The rods are not even close to the pan.
I bought a Canton oil pan about 5-6 years ago and I bought a BMR k-member about 3 years ago and had them make it special being a 1/2 lower than normal.
I believe that Canton changed their style at some point because my pan was rubbbing on the original steering rack and it would have hit if I would not had it special made.
You don't read of that anymore.
Old Oct 27, 2006 | 08:50 PM
93 4mula's Avatar
Alright. Just checking because I dont want to spend that kind of money on a pan and then have to clearance it for my stroke.
Old Oct 27, 2006 | 09:18 PM
CALL911's Avatar
The rods will clear just fine, as they do in my 383.
Old Oct 27, 2006 | 09:21 PM
gixxer92's Avatar
Just a note, if your using FLP/Dynatech headers, mine are the older FLP's with a canton oil pan, they touch on the LH wing of the oil pan.
My engine shop had to clear the scrapers in the oil pan a little for the crank.
Side note on an above comment, the pan has plenty of clearance to the steering rack, now.
Old Oct 27, 2006 | 10:22 PM
93 4mula's Avatar
Yea, What size rods do you have? I dont want to buy that 300 dollar pan if I have to clearance it.
Old Oct 27, 2006 | 11:40 PM
gixxer92's Avatar
6" rods
Old Jan 9, 2007 | 12:11 AM
93 4mula's Avatar
So the Canton pan will clear the bmr tubular k member? Im going with the madman manual rack. Will I have any problems with it hitting that either?
Old Jan 9, 2007 | 01:03 AM
lethal93ta's Avatar
the only way to know if it will clear is to mock it up, I had to clearance the crank scraper on mine I have manley 5.7 rods and the bolts hit the scraper, a little tapping with a ball pein hammer and problem fixed.
Old Jan 9, 2007 | 11:26 AM
93 4mula's Avatar
Im talking about will the pan clear the bmr k member
Old Jan 9, 2007 | 02:19 PM
Mr_Bond's Avatar
Sure it will
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
sseeya
Apr 9, 2015 06:38 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
