Canton 242T Oil Pan Questions
Old May 13, 2010 | 06:05 AM
GreenZLT1's Avatar
I'm installing this pan on Friday and have a question. I'm going to remove the factory windage tray due to the Canton pan having one. Am I going to be able to use the stock longer main cap bolts that hold the factory windage tray? Or are they going to hit?
Thanks,
Rob
Old May 13, 2010 | 07:54 AM
wrd1972's Avatar
I would just hold the pan up there and see if it hits or take some measurements. If there is no need to pull those cap bolts, then dont.
Can you post some pics of that pan especially in the sump area?
Old May 13, 2010 | 07:16 PM
GreenZLT1's Avatar
Old May 13, 2010 | 08:29 PM
wrd1972's Avatar
What does the pickup look like? Are you using a Canton part.
Old May 13, 2010 | 09:43 PM
jasonface's Avatar
I remember on mine that I had a problem with the slayed 4-bolt caps hitting in a couple of spots, but I don't recall about the main cap bolts. I have pics somewhere, I'll try to find them. I didn't use the stock cap bolts, but it seems there was plenty of room except for the splayed caps themselves. I'll try to dig up those pics, I'll post 'em if I find them.
Old May 14, 2010 | 12:12 PM
GreenZLT1's Avatar
Canton Pickup
Old May 14, 2010 | 12:49 PM
RamAir95TA's Avatar
I used the 20-023 with my 242T.
Old May 14, 2010 | 02:02 PM
wrd1972's Avatar
There have been some recent posts of guys claiming thet their aftermarket oil pans hit the steering rack.
If you dont mind, please measure the distance between your current pan and the new Canton one and post the findins up if its not too big a deal.
I will be watching this thread all weekend.
Old May 14, 2010 | 02:11 PM
jasonface's Avatar
I heard this was a problem with the early Cantons, but they fixed that issue. I'm running one and it fits perfect with my stock rack.
Old May 14, 2010 | 03:34 PM
wrd1972's Avatar
Originally Posted by GreenZLT1
Canton Pickup
Does this pickup still have to be "set" then welded. Or does it bolt on and become set?
Old May 14, 2010 | 04:19 PM
96azhawk's Avatar
I used the same setup and we somewhat pressed in the pickup, but with it bolted to the pump, it did not seem like there was any need at all to weld it.
As for the main cap bolts... wish I could help, but we used ARP.
Old May 15, 2010 | 07:27 AM
koolaid_kid's Avatar
The pickup bolted on, and I used Loctite to make sure it stayed there.
Personally, when I went Canton, I spent the extra coinage to go ARP. No brainer.
Also, the oil dipstick did not fit well, and I had to make several trial runs to get it over my splayed mains.
And the pan itself fit like crud. Warped and difficult to fit. Had to purchase longer end bolts to get it going, and then work from there. Real PITA.
Old May 17, 2010 | 05:14 AM
GreenZLT1's Avatar
Well I got the pan on, it slid right in. But it is leaking from the rear of the pan, by the rear main seal. It seemed like the gasket did not want to fit right and I thought it would just "squish" into place. Off comes the pan.
The pan cleared my steering just fine.
Rob
Old May 17, 2010 | 06:26 AM
jasonface's Avatar
Well ......... it slid right in. .......leaking from the rear ...........did not want to fit .......I thought it would just "squish" into place.........
Rob
A little creative editing, and TaaaDaaa!
Sorry, couldn't resist. For some reason I was reading your post and those words just sorta stood out.
Back to the pan, what do you mean by the gasket didn't seem to fit? Are you using the factory type molded gasket? And also, was there a gap near the mid point, or was it leaking by the corners?
Old May 17, 2010 | 08:08 AM
wrd1972's Avatar
Any chance you are using the blue Fel-Pro gasket?
