cant run over 120 mph 97 Z28
Old Jun 8, 2011 | 08:51 PM
  #16
MikeLT1Z28's Avatar
Re: cant run over 120 mph 97 Z28
he said it does it in 5th too, 5th should be good with 3.42's up to about 150. have you noticed a specific rpm it does it at? i'm thinking since 6th is a steep ratio, maybe it's dropping it far enough below the rpm that it will still pull. slowly drive thru the whole rpm band in about 2nd gear, see if it stumbles any. almost sounds like an ignition problem.
Old Jun 8, 2011 | 09:04 PM
  #17
bw_hunter's Avatar
He stated 3.73's. Both 5 and 6th are overdrive....
Old Jun 8, 2011 | 09:42 PM
  #18
In 4th gear, with the 3.73's it would hit the stock 5,805RPM rev limiter at 119MPH. In 5th gear it should reach maximum drag limited top speed of about 155MPH.
Check the build code tag for RPO "QLC" which would indicate it left the factory with the Z-rated tires, and they have the MPH limiter programmed as "255".
Do you really have a 235/40-17 tire on the front? That's about 1.2" smaller diameter than it should be.
Old Jun 9, 2011 | 01:10 AM
  #19
Fatdog2's Avatar
Yes,could just be the coil wire.My02.
Old Jun 9, 2011 | 03:30 PM
  #20
Procharged94Lt1's Avatar
Originally Posted by eperkins8199
I got it up to 130. havent tried to go past that. Im worried it might hurt something.
Like your driving privileges when you get caught?
Old Jun 9, 2011 | 07:21 PM
  #21
eperkins8199's Avatar
there is no rev limiter. I can run the rpms up to 6500 and it doesnt act stupid.
I installed a new opti spark harness on it and it still does it. When i bought the car the owner said that the motor has been rebuilt. My cuz builds lt1 and he cant figure it out either.
Old Jun 9, 2011 | 07:23 PM
  #22
yep thats the tire thats on the front and it looks stupid. should have gone bigger.
Old Jun 9, 2011 | 10:58 PM
  #23
If there is no rev limiter, the programming is not stock.
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Jan 20, 2015 01:30 PM
NewsBot
Dec 17, 2014 02:50 PM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
