cant run over 120 mph 97 Z28
Old Jun 8, 2011 | 06:42 PM
eperkins8199's Avatar
the car will run to 120 but it feels like it governs out there. But if I shift into sixth it will climb past that. Cant figure out the problem. HELP
Old Jun 8, 2011 | 06:52 PM
RamAir95TA's Avatar
Re: cant run over 120 mph 97 Z28
Need some more detail on the car.
Old Jun 8, 2011 | 06:57 PM
bw_hunter's Avatar
It probably is governed. Some V8 F bodies came with 235-16 tires and got a 112 mph top speed. It can be tuned out easily enough.....
Old Jun 8, 2011 | 07:02 PM
its pretty much stock. ok it sounds like it back fires and starts jumping then i shift in 6th i can climb past. It does it in 4th and 5th gear.
if it was governed out then i shouldnt be able to climb past
Old Jun 8, 2011 | 07:04 PM
bw_hunter's Avatar
What does your speedo go to?
Old Jun 8, 2011 | 07:11 PM
160. I have 3.73 gears in it. stock T56.
Old Jun 8, 2011 | 07:12 PM
MikeLT1Z28's Avatar
so it cuts out in 4th and 5th at 120 and will climb past it in 6th? how far past? all 4th gens that didn't come with Z rated tires got the speed limiter.
Old Jun 8, 2011 | 07:15 PM
I got it up to 130. havent tried to go past that. Im worried it might hurt something.
Old Jun 8, 2011 | 07:17 PM
MikeLT1Z28's Avatar
160? you mean 150 with the 5 extra gradients?
Old Jun 8, 2011 | 07:19 PM
MikeLT1Z28's Avatar
any mods other than the gear?
Old Jun 8, 2011 | 07:20 PM
oops. yes 150. it pretty sad when i can beat other cars then its all over when i reach 120
Old Jun 8, 2011 | 07:22 PM
basic bolt on. air foil, cold air, exhaust, manuel elec fan switch
Old Jun 8, 2011 | 07:25 PM
MikeLT1Z28's Avatar
stock tire size? or what size wheel/tires
Old Jun 8, 2011 | 07:30 PM
rear is 17x10.5 275/40z/17
front is 17x9 235/40z/17
Old Jun 8, 2011 | 08:09 PM
bw_hunter's Avatar
If you don't have a top speed limiter, you're running into the rev limiter in 4th gear, the rev limiter cuts fuel and when the engine revs drop adds it back. That's a likely cause of the backfire.....
