Can't get nuts off ARP head studs
Old May 19, 2007 | 11:57 AM
blue's Avatar
The nuts in the very front and the rear are impossible to get a socket on (5/8 deep, six point). The socket hits the spring where it sits on the head, and I don't think it would go on even if the springs were removed. I'll be grinding down a socket today to try to get it think enough to fit on there. AFR 190 heads, but I think the situation would be the same with any head. This has been an unwelcome little surprise.
By the way, when torquing the heads back down, should I just follow the standard pattern and steps from Haynes? 65 ft-lbs final torque?
I bought this car from a member here Camaro_SS/R about 6 weeks ago. It's been quite a story and I'm not happy about it at all. I'll post the whole thing when I find out what's wrong with it. Something came apart and the only thing left on the car to take apart is removing the heads.
Old May 19, 2007 | 11:59 AM
blue's Avatar
Oh, also, will I be able to get the heads off the studs with the engine in the car?
edit: We tried various brands of sockets to find one thin enough to get in there and none would fit. Then we found a spark plug socket with built in extension that fit. Only other option is to grind a socket until it will fit. Also, you can get the heads off in the car; you might have to pull the studs out first though; I don't remember, it was a while ago. :edit
Victor Lamb
Aug 26, 2017 02:52 PM
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
