can't figure out the problem
Old Dec 15, 2004 | 09:26 PM
camaro325's Avatar
My car would run rough when it got hot so I replaced the ignition module, and it was fixed, however my other problem was not, sometimes when I driving,when I touch the gas pedal at all the rpms will drop at the second I touch it. it will go back to normal after like a minute or two, I noticed today when I kept tapping the gas to try and make it go back to normal, when the rpms finally started to go up instead of going down, it sounded flooded and then cleared
keep in mind, this problem doesn't happen all the time, and when it goes back to normal it runs great
Old Dec 15, 2004 | 10:46 PM
Scrote's Avatar
Re: can't figure out the problem
Is this only happening when the engine is up to operating temperature? Or does it do it at all engine temps? Could be a fuel delivery problem, its hard to say with the information you posted. I would put a fuel pressure test gauge on the car and drive the vehicle. If the fuel PSI goes down under load i wouls suspect the pump or fuel pump relay...the relay generally show itself failing when the engine is warm, so if you only notice a loss of PSI when the vehile is hot, look at the relay first, make sure the pump is getting 12 volts.
Good luck man,
Erik
Old Dec 16, 2004 | 11:41 AM
camaro325's Avatar
the fuel pressure is at about 35psi and this problem happens intermediately, I think it usually happens when the car is hot
Old Dec 16, 2004 | 03:47 PM
camaro325's Avatar
it is now starting to run like **** again, I don't understand this car, I am having so many problems it never ends, every week I've been buying new parts or saving up for them
Old Dec 16, 2004 | 06:06 PM
slopokrodrigez's Avatar
Have you cleaned the MAF lately? Did you soak the filter in oil? Did you pull the screen out of the MAF?
Inquiring minds want to know
Dave
Old Dec 17, 2004 | 01:09 PM
camaro325's Avatar
well I bought the car with no screen on the maf already, I haven't cleaned it yet, what should I use to clean it ??
Please help, this problem needs to be resolved and don't have alot of money
Old Dec 17, 2004 | 01:15 PM
SLeeper94Z's Avatar
Unplug your 02 sensors for awhile let the car run in open loop
see if that does trick
Old Dec 17, 2004 | 07:13 PM
camaro325's Avatar
well, I cleaned the maf sensor, but still no difference
Old Dec 17, 2004 | 07:19 PM
tryintogofast's Avatar
Any SES light on during or after these incidents? Could be lots of things right now...damaged/mixed up sensors, bad spark, not enough fuel, too much fuel. I had same type of issue but it was a clogged fuel filter. Too many possiblities right now to give any advice though.
Mike
Old Dec 20, 2004 | 12:12 PM
camaro325's Avatar
Ttt
Old Dec 20, 2004 | 10:05 PM
camaro325's Avatar
Unhappy Re: can't figure out the problem
c'mon, someone please help me out
AlaskaZ28
Apr 17, 2015 08:54 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
smokin25th
Jan 1, 2015 09:06 AM
1LEThumper
Jul 14, 2003 12:45 PM
BOOGER
Jul 25, 2002 02:42 PM
