can you relocate LT1 MAF in front of TB?
Old Nov 10, 2006 | 09:23 AM
Bolt-on Bob's Avatar
Well, after two hours of sleep this morning I'm home as a new F-body owner. Flew into Washington, DC last night at 9:00pm and drove straight home to NC arriving at 5:00am. Picked up a '94 A4 hardtop Formula that I plan to transform this winter before I even put plates on it; Weld wheels all around with Hoosier drag radials, LTs, race mufflers, Yank SS3600, 4.56 gear, BMR suspension components, considerable efforts to lighten (AC/heater, EGR, smog delete, etc.), Ed Wright tuning, blah, blah, blah ... Goal is to have a street legal, bolt-on car that can run IHRA Pure Stock in B/PS (race weight of 3194 with my 6'2" 230 butt) and run under their 12.45 index (8.10 in the 1/8).
First (of many) questions is can I relocate the MAF in front of the TB? I had a bolt-on Impala SS and I got an OEM boot from Dal (from a LT4 C4 IIRC) that positioned the MAF directly in front of the TB (have to extend the wires I know). I didn't run an air cleaner which gave you a direct shot of air with no "bends" to go around. Looking at this car this morning (in the sunlight for the first time) I'm not sure there is room on the front of the engine to do this. Has anyone else repositioned their MAF? Pics would help also if you had.
Appreciate the help and can't wait until next spring!!
Old Nov 10, 2006 | 10:29 AM
reamo04's Avatar
i know that there was a guy on here not too long ago that had a SS hood and used the LS1 intake that went straight off the TB, so yes, it can be done.
1redTA's Avatar
re
tb=throttle body? the maf is already in front of the throttle body
Old Nov 10, 2006 | 10:33 AM
Actually, the elbow makes a 90 degree bend in front of the throttle body positioning the MAF to the right (as you look at the engine) of the intake manifold, continuing on then into the air cleaner. I'm sure that when the air has to "go around it's elbow to get to it's shoulder" it kills horsepower. The LT4 boot puts the MAF directly in front of the throttle body making it a straight shot.
Old Nov 10, 2006 | 10:39 AM
1redTA's Avatar
re
I don't think it cares, a straiter shot through the induction is what all we Lt1 guys want/ LS1 type setup is awesome if you can do anthing like that it can only help ,ART
Old Nov 10, 2006 | 10:55 AM
The stock WS6 package positions the MAF sensor about 5" in front of the throttle body. You can use the $6 Fernco sewer pipe coupling for a nice neat, smooth transition. I don't have an MAF, but yuo can see where it fits in the WS6 seutup:
Old Nov 10, 2006 | 01:04 PM
That's what I was looking for! Thanks Injuneer. By the way, I have pictures of your car bookmarked on my computer as the direction I want to head with mine. On that fitting; will the front accept a 3.5" MAF and if so, do you know off hand what size both ends are? Thanks!!
Old Nov 10, 2006 | 05:24 PM
The Fernco sewer pipe connecter is part #1056-33, which indicates its for coupling 3" plastic pipe. The actual inside diameter of the coupling is about 3.38" (85mm). Its large enough that after heating it up a bit in boiling water, it will slide right over the oval throttle body flange.
http://www.fernco.com/1056.asp
Old Nov 11, 2006 | 11:17 AM
Thanks! Off to Lowe's Home Improvement I go ...
Old Nov 12, 2006 | 08:03 AM
DrivingZiggy's Avatar
I also have the Fernco on my ram air set up. With MAF.
HectorM52
Jun 23, 2016 08:42 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
thenewkid
Nov 27, 2014 09:41 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
