Can we use 1.7 Or 1.8 RR
Old Aug 9, 2003 | 05:36 PM
Farc's Avatar
Question Can we use 1.7 Or 1.8 RR
They are used in the 5.3L LM7 99 plus silverado the 1.8 are after market but the 1.7 are the stocke ones.
Old Aug 9, 2003 | 05:59 PM
1994TransAm's Avatar
i dont think so. otherwise we would have done it
Old Aug 9, 2003 | 06:30 PM
You can't compare the LS1 derived cast iron Silverado engines to the LT1... the entire cam and valve train setup is completely different.
Jesel made prototype 1.7 RR's for the LT1 in 1995. I was offered a set for $1,300.... a bit on the pricey side. They were run on a nitrous LT1 raced by Bryan Truppi in the mid 90's. The car was pretty fast for the time. Truppi-King High Performance did dyno testing for Jesel at the time. Don't know if they were ever sold commercially. But I suspect that 1.7's have been done on other LT1's. The Jesel and T&D shaft rockers are 1.7's. If you need that kind of lift, just get a cam with the correct grind, and run CC Pro-Magnum 1.6's.....
Old Aug 9, 2003 | 06:44 PM
kgkern01's Avatar
Scorpion makes some 1.7 RR for LT1. Here is a post from our local KY Fbodies site where a guy switched from 1.6 to 1.7 RR with hotcam and picked up a few RWHP.
http://www.kyfbodies.org/vb/showthre...&threadid=9143
Old Aug 9, 2003 | 07:03 PM
96z's Avatar
96z
Do what Fred said and get a cam ground with more lift...cheaper and way easier....
Old Aug 9, 2003 | 07:26 PM
KeVMaN's Avatar
damn 15hp increase and he had 1.6 rollers before that....
Old Aug 9, 2003 | 09:40 PM
Red 97T/A A4's Avatar
Sar2k uses 1.7's in his LT1. Do a search or drop him a line. He's always replied when I've emailed/pm'd him.
Old Aug 9, 2003 | 11:02 PM
Farc's Avatar
Wow nice numbers,
I ask this because I own a 2000 5.3L Z71 and may buy the RR 1.8 for she and use the olds 1.7 RR in my 93Z 28 this will be nice If work, I know I can have the lift for a cam but my Z is all stock and dont want to buy a cam now only Port P. and mill the heads for more compression I have here 95 unlead may some 12.5 to 1 will be nice and the RR I dont see this that hard to install.
Old Aug 10, 2003 | 12:17 PM
Farc's Avatar
ttt
ttt
Old Aug 11, 2003 | 06:13 AM
kgkern01's Avatar
The RR off of your 2000 5.3L truck is LS1 based, which has a completely different valve train design, so you cannot swap the RR from your truck to your LT1.
Old Aug 11, 2003 | 06:28 AM
magius231's Avatar
looking at the price of the Scorpion rockers, these things don't cost any more than regular 1.6 rockers (and in some cases quite a bit less). I would think this would be a great way to run additional lift without having to significantly change the RPM range of whatever cam you choose, and without having extreme lifter ramp angles...I don't see the disadvantage here?
Old Aug 14, 2003 | 04:11 PM
Farc's Avatar
Thumbs down
I think the same and this will be great to run wit stock cam and then when we have cams will have bigger lift to.
Cam's maro
Aug 11, 2015 07:45 AM
1995zee28
Apr 6, 2003 07:18 PM
djcam
Jan 12, 2003 05:22 PM
donot_4get
Sep 14, 2002 08:03 AM
2001CamaroGuy
Jul 23, 2002 12:16 PM
