can someone tell me what's wrong? Datalog inside....
Old Jan 2, 2007 | 09:56 PM
street demon2k3's Avatar
well i finally got around to buying a cable to datalog, and got a file recorded. I replaced the pcv valve and took off the breather on the pass. side valvecover, now everything should be working but the car runs like ****. compared to when i had the breather and plugged vacuum line and pcv valve the car is running very horrible. only thing is how can i post the tts datamaster file on here? or should i email it to someone to take a look?
i noticed that the knock count in open loop(166) and then closed loop it was like 33k. i dont know what the hell it might be except for maybe the exhaust leaks at the collectors or maybe a rocker is loose which i doubt because id prolly hear it. on a WOT run i noticed that the injector duty cycle went to like 99% which might explain my car going lean on the top end sometimes. i really need some help guys and any feed back is appreciated.
Old Jan 2, 2007 | 10:22 PM
You need to find an FTP site that you can upload the file to. If you upload it in .uni format, only people with DataMaster will be able to look at your file. If you upload it in .csv format ("export" option in DataMaster) any can look at it with Excel.
Old Jan 2, 2007 | 10:37 PM
any way i can send it to you Injuneer? i'll try and put in in .csv format so everyone can take a look at it. also what's a good FTP site to upload the file to?
Old Jan 2, 2007 | 10:51 PM
i changed it over to .csv format and opened it on excel but since i just purchased the laptop i need to purchase the product software to view the file. i can email it to someone if you guys can take a look at it for me.
Old Jan 2, 2007 | 10:59 PM
Go to the "Computer......." forum and look through the threads to find out where others have used FTP sites for their data logs.
Old Jan 2, 2007 | 11:52 PM
here's the .uni file
http://www.freefileupload.net/file.p...02970/run1.uni
and here's the .csv file, dont know if i converted it properly
http://www.freefileupload.net/file.p...393/Run1.2.csv
hope this helps, please let me know what's wrong with the car!
Old Jan 3, 2007 | 10:42 AM
The website is too busy to show the webpage
Old Jan 3, 2007 | 05:18 PM
i was trying to go through the Computer forums and tried a search but i get a 404 forbidden access message. cant figure out why, but does anyone have the same problem. off topic but i've been trying to find a site but to no avail. i can email it to anyone that wants to take a look at it.
Old Jan 4, 2007 | 01:31 PM
i tried to upload it to some other sites but they didnt work either. so i uploaded it to the same website. here it is:
http://www.freefileupload.net/file.p...38429/run1.uni
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
