can someone post a picture
Old Apr 16, 2004 | 10:00 AM
Red 95 PITA's Avatar
Going to replace the upper o2 sensor today, can anyone post a picture or explain where exactly its at?
Old Apr 16, 2004 | 10:13 AM
PatriotTA's Avatar
I can't remember which is which, but I know one O2 sensor was in the y-pipe, about where it bolts up to the manifold (I think that was the drivers side) and the other one (probably passenger side) was actually in the manifold. Just get under the car with a flashlight and look to where the y-pipe meets the manifold.
Old Apr 16, 2004 | 11:12 AM
Okay, i crawled under the car and found a o2 sensor directly in front of the oil filter. Would this be the upper? i cant seem to find the other one. Any idea?
Old Apr 16, 2004 | 11:30 AM
PatriotTA's Avatar
I don't know where you got the idea of upper and lower, they usually go by left bank (driver side) and right bank (passenger side). So if its near the oil filter, you've located the driver's side. Now look at about the same height on the other side of the motor, and you'll see the other one. Hope this helps you out.
Old Apr 16, 2004 | 11:44 AM
Okay i found the other one. they are both at the bottom of the headers where the header meets the Y pipe. Now a new question. The one closer to the driver side tire looks alot thinner then the other one. Is that normal? they both have the flat 4 pin connector.
Old Apr 16, 2004 | 12:14 PM
PatriotTA's Avatar
No, they should be the same size. One of them may be stock and the other one aftermarket or something like that. Either way, I wouldn't worry about it. Its not a big deal.
Old Apr 16, 2004 | 01:23 PM
For stuff like this, its always a good idea to start with Shoebox's Tech Pages....
http://shbox.com/1/4th_gen_tech1.html
http://shbox.com/1/ho2.jpg
DirtyDaveW
Dec 1, 2016 05:37 PM
ChrisFrez
Feb 22, 2015 08:47 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
cmdeshon
Dec 12, 2014 10:51 PM
