Can this be Soldered... (pics)
Re: Can this be Soldered... (pics)
you can probably buy the whole plug from a dealer for a couple bucks, if not you can get a tool to take the pin out of the plug to re attach the wire to. or you can carefully solder it!!!
Yeah, a competent person could solder that. You want to tin the leads on both the connector and the wire...then, you should be able to get solder to flow. Be sure to use heat shrink and electrical tape around both connections.
You can buy pigtails from the dealership for around 15 bucks. YOu reallly ought to replace the whole thing or take it to someone who can recrimp a pin on it.
Never skimp out on wiring things.. It will save you abunch of hassle down the road.
Originally Posted by danhr
crimping it would be easier and you would get better continuity.
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cmsmith
Jul 10, 2015 07:19 PM
