Can this be Soldered... (pics)
Old Nov 16, 2005 | 05:32 PM
97BBlackZ's Avatar
Like the title says. Just wondering if it can. I don't know much about soldering so i figured i'd ask even though i was pretty sure.
Old Nov 16, 2005 | 05:37 PM
cammed_aro Z28's Avatar
Re: Can this be Soldered... (pics)
you can probably buy the whole plug from a dealer for a couple bucks, if not you can get a tool to take the pin out of the plug to re attach the wire to. or you can carefully solder it!!!
Old Nov 16, 2005 | 05:38 PM
97bowtie's Avatar
Yeah, a competent person could solder that. You want to tin the leads on both the connector and the wire...then, you should be able to get solder to flow. Be sure to use heat shrink and electrical tape around both connections.
Old Nov 16, 2005 | 05:42 PM
danhr's Avatar
crimping it would be easier and you would get better continuity.
Old Nov 16, 2005 | 05:46 PM
Alvin@pcmforless.com's Avatar
You can buy pigtails from the dealership for around 15 bucks. YOu reallly ought to replace the whole thing or take it to someone who can recrimp a pin on it.
Never skimp out on wiring things.. It will save you abunch of hassle down the road.
Old Nov 16, 2005 | 06:18 PM
97BBlackZ's Avatar
Alright thanks for the info guys thats what i needed to know.
Old Nov 17, 2005 | 12:20 AM
Blownbird355's Avatar
Soldering is alwaws better than crimping hands down. He may have ment to recrimp new connector on. That would be good as factory.
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cjamen
Jul 27, 2015 12:48 PM
cmsmith
Jul 10, 2015 07:19 PM
