Can installing a Walbro make me run rich?
Old Jan 20, 2009 | 03:06 PM
brickonwheels's Avatar
I recently installed a Walbro 255lph fuel pump along with a nitrous kit. When I did my NA run on the dyno, I noticed that I was running really rich, 10.5 or so. the car is on the same tune as it was before, and it was in a lot better shape, with an AFR in the 12s. Can simply adding a higher flowing intake cause my 94 LT1 to run rich, without adjusting the tune or injectors?
Old Jan 20, 2009 | 05:08 PM
KajunKadillac's Avatar
Well, from the looks of it, a larger intake should make it more lean, that is a powerful fuel pump. Im putting a similar pump on my engine build this summer, but on a 383 build. Looks like you may just need a tune for it. Probably a chassis tune is in need here. But look on the bright side for now, running rich isnt as bad as running lean like i am now .
Old Jan 20, 2009 | 06:59 PM
WS6T3RROR's Avatar
Depends on exactly how it was tuned before. The fuel pump shouldnt make a diff unless it has bumped the pressure up alot or the previous pump was not cutting the mustard with supply at high rpm depends on how they tuned though. A dirty maf will do exactly what you're describing. Hard to diagnose with no datalogs or other info.
Old Jan 21, 2009 | 05:21 AM
Originally Posted by brickonwheels
Can installing a Wallbro make me run rich?
Aren't you asking about a higher flowing fuel pump?
Old Jan 21, 2009 | 07:16 AM
87bandit's Avatar
if your old pump was dying and he had to tune it to make the fuel operate on a heavier demand to get the required fuel I could see it happening I guess
Old Jan 21, 2009 | 08:09 AM
That Camaro Guy's Avatar
If your old fuel pump was able to keep the same pressure you're running now, no. If your old fuel pump was slacking and pressure was dropping off then the addition of a new fuel pump adding pressure would cause it to run rich without the tune being adjusted. For instance, putting a walboro on a bone stock car would change nothing at all. Putting a walboro on a previously fuel starved engine would cause it to no longer be fuel starved.
Old Jan 22, 2009 | 12:11 AM
Yes, I meant fuel pump. This is what I figured, and my tuner has confirmed it. Time to save more money and get the tune adjusted.
Old Jan 22, 2009 | 10:22 AM
WS6T3RROR's Avatar
Learn to do it yourself? Its not the voodoo many would have you believe.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
Queens94z28
Dec 20, 2014 09:11 PM
ro2207
Dec 4, 2014 06:18 PM
