Can I delete??/Idle Issues
Old Oct 12, 2011 | 10:45 PM
camz28ryan's Avatar
Not sure if my signature is posted so here is update. I have done the following.
1996, LT1, 6pd manual
New rebuild
CC503 Cam
Stock TB, Injectors, lifters and pushrods.
Longtube pacesetter headers.
1. took off smog pump and plugged all holes
2. Removed o2 sensors on rear and tuned out
3. Installed new front o2 sensors on front at the collectors in hole provided by pacesetter.
4. Installed true duals, no X pipe with magna flow exhaust.
5. New opti, vent type and vaccum's are hooked up with check/back pressure valves. ( little blue looking things that look like a kids top)
6. Installed 160 degree thermo stat
7. Replaced ALL vacuum lines, should have no leaks with new hoses.
I have one question about deleting some stuff and one issue.
1. Can I delete the EVAP canister purge solenoid valve and plug lines?
2. Can I delete the other solenoid thing(couldn't find the name but it sits next to the EVAP purge sonenoid and is connected to it. It's number 11 on shoe boxes site labled EVAP exploaded view and hooks to fuel bundle on driver side.
3. Can I delete the vacuum hoses on opti and plug off?
Issue: First off I ran the car a few days without front 02 sensors and havent had the car tuned after we built the engine.
The idle was fine for a couple of days but now it's jacked. Here's what it's doing. The car is jerking really bad rpm was ranging from 800 to 1300 and coming to a stop you could put it in neutrual and rpm would stay at 2000 until you come to a stop.
I followed shoe boxes instructions on resetting IAC, it seemed help somewhat but still not right. Should I get the car tuned first and see if that fixes things or what?
Do you have any info I can pass to my tuner that would be helpful?
Old Oct 12, 2011 | 10:49 PM
JGuy07's Avatar
Re: Can I delete??/Idle Issues
Why would you want to get rid of the opti vac lines? The whole reason behind them is to keep gases and moisture from building up in the opti and fouling the sensor or causing other damage.
Old Oct 12, 2011 | 10:52 PM
Why do you want to delete the vent and vacuum lines from the Opti? The vent system removes ozone that causes the internals to corrode. It would not improve performance in any way, and will probably shorten the life of the Opti.
The EVAP system recovers fuel vapor, so there's a slight gain in fuel economy. And it eliminates the fuel stink at the rear of the car that will be present after you delete the EVAP system. Again, no performance gain.
The "other solenoid thing" is the vacuum detector that is part of the OBD-II diagnostic system for the EVAP system. If you delete it, you will have to have the diagnostic programmed out of the PCM.
Old Oct 12, 2011 | 11:44 PM
camz28ryan's Avatar
Ok thanks for the info. What about the idle issues?
Old Oct 12, 2011 | 11:49 PM
camz28ryan's Avatar
Should I get it tuned to see if it fixes the problem or should it be fixed prior to tuning?
Old Oct 13, 2011 | 04:39 AM
RamAir95TA's Avatar
You need to have the car tuned for the rebuild/cam to have a prayer of the car running correctly before anything else.
Old Oct 13, 2011 | 09:51 AM
camz28ryan's Avatar
I know it needs to be tuned, my concern was whatever that is causing the idle issues would make the tune pointless. If the iac was bad would it still make sense to get the car tuned before you get the iac fixed?
Injuneer, what are your thoughts on this and whats your guess on the idle issue.
Old Oct 13, 2011 | 11:15 AM
vangill's Avatar
U should get a tune and then start diagnostic. The tune
Could be a problem
Old Oct 13, 2011 | 05:55 PM
camz28ryan's Avatar
I'm getting it tuned monday but it ran fine for a few days, so I'm thinking it's a seperate issue. That is not to say I don't need a tune but it was fine for a few days. The idle problem all started the day we had heavy rain and my son said he ran through a good size puddles. If the opti got wet would that jack everything up? If so what do we do? Also after the idle issue we replaced some vacuum hoses off of the vacuum detector and it had quit a bit of water/ condensation inside if the solenoid. What would cause that????
Old Oct 14, 2011 | 08:30 PM
camz28ryan's Avatar
Just a update, found a head gasket leak. Builder is sending a wrecker. I'm guessing that is most of the problem..
mattstrike
Mar 24, 2015 02:11 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
alex5366
Mar 8, 2015 11:32 AM
armedtrigger
Feb 24, 2015 08:30 PM
DropZ
Jan 15, 2015 10:40 AM
