Can I compete with an Ls1 now....
Old Dec 22, 2005 | 08:30 AM
wrd1972's Avatar
See sig.
Old Dec 22, 2005 | 08:36 AM
BlackScreaminMachine's Avatar
Re: Can I compete with an Ls1 now....
Ok... so we are looking at a
Cold air intake
Decent clutch
Headers
Catback
Roller rockers
TB w/ bypass
mmhmm the extra weight of the vert isnt helping but if you can launch or at least get a stockish auto LS1 from a roll you should pull on him a little. I just dont know the exact weight of LT1 vettes.
What your car could benefit from is a electric waterpump, suspension mods to try and keep the IRS from freaking out, sticker tires, and start looking at a cam.
Even bolt on 6 speed LS1's pull stupid times.
I got a friend with a 02 Camaro, 6 speed. It has a SLP lid, tb by pass, LT headers with out cats to a Borla with open plate, FAST TB, spec 3 clutch, BMR tq arm and rear LCA's. He did 12.51 at 114mph. I get beat from a roll (my car isnt 100%) but I still beat him from a stop with my car bogging.
Again i have a whole lot more done.
Old Dec 22, 2005 | 08:38 AM
wrd1972's Avatar
Whoaaa, mule.
Im in a Camaro Z28.
Dont forget the 4.10's should be able to thump him out of the hole.
Old Dec 22, 2005 | 08:55 AM
AF96Z28's Avatar
I think you could hang with an LS1 even without the gears. The 4.10's make it an easy win for you
Old Dec 22, 2005 | 09:09 AM
curly's Avatar
I think it would be a good race.
Old Dec 22, 2005 | 09:29 AM
woops sorry, i thought I saw vette, my bad
Ok so you should be in the 3900 pound with driver weight. My car with some lightening with out me is 3450 and 3705 with me.... mmmmhmm.
I think you could hang certainly, its a question of whether you can pull, from a stop is where you need to race.
Oh and with the 4.10 gears that can hurt you because blowing the tires off doesnt help anything.
Old Dec 22, 2005 | 09:52 AM
wrd1972's Avatar
When its warm the tires really hook well with the 4.10's.
It also seems to launch really hard without a whole lot of spinning.
Old Dec 22, 2005 | 10:27 AM
About 90% of the time in a race, that the race is won in the 1st 60 feet. Again I am not a fan of huge gearing, often the potential gain from the increased ratio is negated from the possibility of blowing the launch or 1st gear is run through so quickly. On the otherside of it, a car will all the power in the world, cannot win a race if they cant get the power to the rear and not spin.
Old Dec 22, 2005 | 11:27 AM
96flame's Avatar
Provided the LS1 is stock you should be okay. Most LT1 6spds are right around 13.9-14.1 and stock LS1 are 13.2-13.5 depending on driver skill with around 2.0 60' time.
Old Dec 22, 2005 | 11:29 AM
1racerdude's Avatar
The gear will work as long as the tires hook. I think ya will need more mods to run with some of the bolt on LS1 I have seen around here.
Old Dec 22, 2005 | 11:35 AM
wrd1972's Avatar
Ive got LCA's and a pan hard rod on the way. That will help with traction.
One day I will do an LE1 package but thats off in the future.
I might consider the electric water pump.
Old Dec 22, 2005 | 12:18 PM
Eddie Z-28's Avatar
I was taking down mildly modded LS1's at the track with my car. Mods in sig.
Old Dec 22, 2005 | 12:37 PM
JakeRobb's Avatar
Super Moderator
Get to a track and come back with times. That's the only real way to know who you can hang with.
I think you'll be hard pressed to beat your typical mild bolt-on LS1 (mine once I get tires, for instance), but I'll bet you can take most stockers.
Old Dec 22, 2005 | 12:46 PM
But be aware, of putting a sticker tire on a 6speed/10bolt car, if you get the right amount of hook (the 1.7 60 range) your rear end will be in danger. My auto/10 bolt at the time was fine but the posi was failing. I would be worried about an 6 speed beating up on the rear with a dead hook.
Old Dec 22, 2005 | 05:55 PM
1995greenTA's Avatar
You have a good chance of spanking a stock ls1.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
