do i need a spacer for 94 style hub on a 96z?
Old Dec 22, 2005 | 05:50 PM
red96z's Avatar
i have a 96z and an obd1 conversion. the reluctor ring wont fit with a double roller timing chain and the obd1 doesnt even read the crank sensor so i put it back together with no ring and a 94 style hub. in someones previous post i read if u use the 94 style hub u need a spacer. but i have a double roller so am i fine hub only no spacer??
Old Dec 22, 2005 | 05:55 PM
red96z's Avatar
Re: do i need a spacer for 94 style hub on a 96z?
btw i had to grind the keyway down flush to the gear. sorry im beating this to death i just dont need any more problems and i almost have it together and i dont want to have to tear it down before i crank it. also if anyone cares it has only about two days of work left then to the dyno will post numbers!
Old Dec 22, 2005 | 05:58 PM
1racerdude's Avatar
The '94 is the right length without the wheel. '94 don't have a wheel so yours without the wheel is the same as a '94.
Your original hub is shorter so the wheel will fit.
Old Dec 22, 2005 | 06:26 PM
red96z's Avatar
a big thanks man you have been more help than you know!
Old Dec 22, 2005 | 06:36 PM
1racerdude's Avatar
Anytime, glad I could help.
Jeff1904
Jun 5, 2016 05:00 PM
Ericksd
Jan 20, 2016 06:07 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
USN06
Sep 7, 2015 03:30 PM
