Can Hyperteck for **** Up Emission test
Old May 30, 2005 | 06:03 PM
catsnet's Avatar
Question Can Hyperteck for **** Up Emission test
Had my last test done 2 years ago and passed with flying colors
This time after only 4K and this modes: 52mm, stat, MSD the works, LT4 KM and a Hypertech I faild on the "NO PPM" knock problem. their is a whole explanation about the problem cause: EGR, Cat, Plugs Lean A/f mix, Spark Adwance, Cooling and a whole bunch of general BS.
The rest HS PPM and CO% are way below the alowed limit
I'm curious if the Hypertech can be the problem on the car - I was stupid enough not to take off the programing befor going in there because I didn't notice "off road use only" on the box.
Now I have to get the car to the test and try not to fail it bacause they they only give 2 trys in here.
tanks
Alex
Old May 30, 2005 | 06:06 PM
JeffK's Avatar
Re: Can Hyperteck for F**k Up Emission test
I would highly doubt it is the Hypertech. Sounds like it is out of tune.
Old May 30, 2005 | 06:39 PM
madwolf's Avatar
The Hypertech chip does more or less nothing. You have a problem somewhere else.
Old May 30, 2005 | 09:10 PM
catsnet's Avatar
S**T
shuld off mention it
it's a HTPP2 not the chip
thanks
Old May 30, 2005 | 09:24 PM
96vortechSS's Avatar
Agreed, My car actually ran better with the hypertech engine tunning removed.
Old May 31, 2005 | 11:40 AM
96flame's Avatar
I had a Hypertech installed on mine when it was near stock and I passed the Ontario e-test with near zero's across the board. Either you have an EGR valve thats not working or plugged with carbon or the NOX bed in the converter is shot
Old May 31, 2005 | 11:56 AM
red87iroc's Avatar
Re: Can Hyperteck for **** Up Emission test
94 TA I recently bought has Hypertech programming in it.
Easily passed PA emissions testing.
I agree with above advice.
Old May 31, 2005 | 02:55 PM
High on NOx and very low on HC's and CO points to the engine running lean.
Old May 31, 2005 | 03:33 PM
truedualws6's Avatar
I passed CA smog with HPP and all the bolt-ons with the stock cam. This
was OBDII, of course. I would not pass presently, but that too can be fixed.
Old May 31, 2005 | 05:25 PM
96flame's Avatar
It's best not to diagnose emission failures by using the post cat readings. To properly diagnose the failure it should have pre cat readings taken to see whether the engine is just plain putting to many emssions out or whether the catalytic converter is not doing its job.
Old Jun 6, 2005 | 01:54 PM
catsnet's Avatar
that's the case as far as i figured
the problem is i don't really want to fix none of this things coz thy both about to go. and all I needed to do is to get throu the test so I'll have the car
"street legal" for another 2 years.
now - is their any temp. solution to get them fixed and get done with the test
thanks in advance
Alex
KYWes
Jun 14, 2022 06:52 AM
cmsmith
Sep 14, 2015 09:25 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
