Can the coolant hoses to the TB be deleted?
Old Feb 27, 2010 | 08:58 AM
onefastmx5's Avatar
I currently have the union to the TB hoses. I'm trying to make more space in the front, can eliminate this hose by capping off the heater hose barb and replacing the "water pump to radiator hose on the driver side" with a new hose that doesn't have the y extension for the smaller hose? Just wondering if this will effect coolant flow in any way.
Thanks,
James
Old Feb 27, 2010 | 09:06 AM
Yes. You will pick up 6HP. Just pull the two hoses off, and connect them together with a barbed fitting and clamps (93-94 only).
http://www.ws6.com/mod-8.htm
If you lived north of the Arctic Circle, you might experience problems with "throttle body icing"......
Old Feb 27, 2010 | 10:17 PM
onefastmx5's Avatar
Sorry if i explained it wrong, but I'm looking to cap off the heater hose T line and replace the upper radiator hose with a single hose, rather than the single to Y output. Trying to make more room for the supercharger mounting and plumbing.
Old Feb 27, 2010 | 10:38 PM
SnakeOiler's Avatar
You could swap over to a '95 heater and radiator hose.
Had to go to shoebox's site to understand the differences of a '94
Old Feb 28, 2010 | 10:46 PM
onefastmx5's Avatar
Just the answer I wanted. I ended up buying a cap and hose for the heater hose. I bought the upper radiator hose for a 97 Z28 and cut it to length... works great.
blac94Z
Feb 15, 2021 09:43 PM
Latronaxe
Jun 10, 2015 02:08 PM
Fatdog2
Apr 27, 2015 10:32 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
cristian1311
Nov 23, 2014 02:22 PM
