My car makes this buzzing noise help.....
Old May 26, 2005 | 03:42 PM
CHELOZ28's Avatar
Hi im new to this website, I have only had my car for three months its a 1995
Camaro z28 with 100k miles. But my questions is this everytime I start it, it makes this loud buzzing noise it takes about 2min then goes away, this only happens when I start the car. One mechanic has told me its my abs pump, it sounds like its sucking in air.......what do you guys think it might be?
Old May 26, 2005 | 03:51 PM
1996camarors's Avatar
Re: My car makes this buzzing noise help.....
hmm check vacuum hoses.
I was going to say fuel pump but you only hear it from the back and it doesnt clear up in 2 mins.
Old May 26, 2005 | 03:59 PM
Sounds more like the AIR pump. Located at the front of the engine, below the driver's side head. Is that where the "buzz" seems to be coming from? The AIR pump runs for about 2 minutes at startup, and then shuts down until the next restart. They corrode and get noisy.
Switching to "modertor" hat.... this is the "Advanced Tech" forum. Generally limited to high tech discussions. Routine tech problems are best handled on the specific forums, e.g. "LT1 Engine Tech". I'll move your thread there.
Welcome to the board.
Fred
Old May 26, 2005 | 04:08 PM
CHELOZ28's Avatar
it seems to be coming from the driver side, next to the radiator and fuse box.
Old May 26, 2005 | 04:20 PM
Z28Horn's Avatar
It is the air pump, little black cylinder on the drivers side of the block. It runs until your converter is warmed up.
Zach Horn
Old May 26, 2005 | 04:25 PM
CHELOZ28's Avatar
thanks for all the help.....I should have joined this site a couple of months ago. How much do they cost and is it a easy to install?
Old May 27, 2005 | 05:31 AM
slopokrodrigez's Avatar
Be sure that's the problem by unplugging it. If you do decide to purchase one, they are about $100
Old Aug 30, 2005 | 02:03 PM
CHELOZ28's Avatar
what is the exact part number on this air pump. Finally went to the dealers, they said they had no idea what this was...b/s
Old Aug 30, 2005 | 03:27 PM
The dealers should know what it is. There was a recall on the AIR pump/system for the 95 and newer LT1's. They should be repairing it for free.
AdsoYo
May 2, 2018 03:21 AM
NewsBot
Dec 21, 2014 06:55 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Dave19yz28
Jan 26, 2003 01:45 PM
