Camshaft Timing and degreeing the cam?
Old Oct 27, 2007 | 10:33 AM
  #16
Originally Posted by cehan
If the cam timing is off, wouldn't you want to offset the cam sprocket relative to the crank sprocket to correct for that? Now if you adjust the cam timing by using an adjustable cam sprocket, I agree that you will throw off the low res pulse signals, but if you use an offset key in the crank sprocket, if seems to me that the ignition timing relationship to the cam position will not be affected and you will bring the cam to its correct relative position with the crankshaft.
When I degreed my cam, I found it to be 2* retarded so I installed a 2* offset crankshaft sprocket key which brought the cam timing spot on. And, just as Javier said, PCMforless agreed that this was the proper method to correct the cam timing.
But moving the cam sprocket relative to the crank sprocket means the Opti is no longer correctly indexed to the CRANK. Spark timing has to be correct relative to the position of the piston, not to the position of the cam. Since both valves are closed on the compression stroke, spark timing has nothing to do with cam timing. Injector timing is another story. You have to consider the movement of the start and end of the pulse width, relative to the opening and closing of the valve, and what happens to the part of the pulse width that exceeds the duration on the intake valve.
Using a key is the correct way to index the cam to the crank. Then you have to address the issue of the cam dowel pin, and whether it is located correctly, relative to the crank.
Old Oct 27, 2007 | 11:50 AM
  #17
cehan's Avatar
Hmmm...I'll have to think about that
Old Oct 27, 2007 | 11:51 AM
  #18
Javier97Z28's Avatar
Moderator
Moving the crank sprocket with an offset crank key has worked for quite a few people on this board with very positive results. Along with a tuner that has seen more LT1 tunes than probably anyone on this planet's opinion of it not being a problem.
So I guess it just works!
Old Oct 27, 2007 | 11:55 AM
  #19
But would it work better if done correctly
Old Oct 27, 2007 | 12:10 PM
  #20
SStrokerAce's Avatar
Fred, question is what is correctly?
Old Oct 27, 2007 | 12:13 PM
  #21
Right. "would not be a problem" seems to infer that there has been an admitted change from normal. Whether a person decides it is worthy of some programming alteration is another thing.
Old Oct 27, 2007 | 12:44 PM
  #22
rskrause's Avatar
Moderator
The injector timing is trivial. A couple of degrees off will make no difference there. However, if you are installing the cam anything other than straight up you absolutely should adjust the spark timing. For every degree you advance the cam, retard the timing one degree, and vice versa. Of course, most often a tune is done after a cam swap and you will be setting the timing to optimum anyway. But even in that case, keep in mind that what the PCM commands is going to be offset by the same amount the as the cam timing in the opposite direction. If you are not doing a tune, you may want to adjust your timing to avoid damage or poor performance due to excessive advance.
Rich
Old Oct 27, 2007 | 11:43 PM
  #23
biggrizzly's Avatar
I have read through everyone's responses and I'm still digesting what has been discussed. I'm just hoping that when I degree the cam, it comes in where it should and I won't have to fiddle with it.
I will be installing an MSD Opti which has an adjustment for timing, I don't know if that will help or hinder.
Thanks for all the responses so far, I'm still all ears on this one.
Old Oct 28, 2007 | 08:53 AM
  #24
cehan's Avatar
OK, I thought about it. When the cam is degreed straight up and you find it to be 2* retarded, for example, doesn't that mean that the cam timing (and the ignition timing in the LT1 because the distributer is driven directly off the cam) is 2* behind where it should be relative to the position of the crankshaft?
So to compensate for this, the 2* offset crank key is used to advance the cam to the straight up position (or another way of looking at it is that you are retarding the crankshaft position relative to the cam). Thus, the ignition timing in this case is not affected.
Old Oct 28, 2007 | 09:27 AM
  #25
1racerdude's Avatar
This will depend on where they put the opti pin in relation to ICL.
Old Oct 28, 2007 | 10:43 AM
  #26
There are two very different scenarios being mixed together here.... one is moving the cam to correct for an incorrect grind, the other is advancing or retarding a correctly ground cam.
Old Oct 28, 2007 | 03:35 PM
  #27
Moderator
I don't see anyone mixing up those scenarios here.
The purpose of the discussion I believe is installing "dot to dot" or "straight up" while correcting a production error, whether it be due to the timing set, or the cam itself.
My purpose on installation with the offset key was to correct for a two degree error I found when installing. I corrected, and installed "straight up" using the offset key.
I don't see the discussion going in the direction of advancing or retarding the cam from the ICL.
Old Oct 28, 2007 | 06:11 PM
  #28
cehan's Avatar
Yeah, I inferred from the original post that the question was about degreeing the cam so it is correctly installed in the as designed straight up position.
Old Oct 28, 2007 | 10:00 PM
  #29
biggrizzly's Avatar
My original question was indeed to figure out how to ensure that my cam is installed correctly as indicated on the Cam Card. It indicates that the cam needs to be installed @ 105.0 intake center line. So what I understand is that I need to install my gears straight up, dot to dot and then degree the cam. It should measure 105.0* at #1TDC on both the piston and cam lobe. Am I correct so far?
If this measurement is off, then I need to advance or retard the cam timing by shifting the crank gear to either the advance key or retard key. Am I still on here?
The only problem is that the cheap chainset I bought to replace my stocker has only one keyway in it. I'm going to return it and get the Cloyes CLO-C-3039. I think that will do it.
Old Oct 29, 2007 | 03:48 AM
  #30
Zachz28's Avatar
Ok so if a cam needs to be advanced/retarded by adjustments in the timing set, what timing sets have the ability to do this?
