Camshaft Timing and degreeing the cam?
I am getting ready to install my new LE2 HC package with a cam spec'd by Bret Bauer. My question is, do I have to degree the cam? or is it ok as is to install straight up in my otherwise stock LT1?
Thanks in advance
Thanks in advance
You should 100% absolutely check / degree the cam when installing.
Don't half *** like most people do, this is one of those things that separates the fast cars from the "I wonder why my car is slow" cars.
For sure degree it. First time I ever degreed a camshaft, I did it the ICL method, with the heads on, engine in car, and it took no more than 40 minutes, start to finish, including building a spacer(Could use washers?) to hold the degree wheel out far enough that it wont hit the accessory bracket.
When I did mine, I was within 3/4 of 1* each time I checked it, at .005, .010, and .020 before and after peak lift on the intake lobe for number one.
Two other questions;
1) I'm planning on using a stock LT-1 timing set, which does not have alternative keyways cut into it to retard or advance the cam, is it essential to use an aftermarket cam gear to be able to make changes to the timing if problems are found when degreeing the cam?
2) With that said, if there is a discepency in the final cam timing other than that which is identified on the cam card, what steps are typicaly taken to fix the issue? I guess the timing set installation would be my first suspect and then possiblley the actual timing set as manufactured. Opinions?
Be careful when you advance or retard the cam. First.... what year is your car (vented or unvented Opti)? It throws the ignition and injector timing off, because of the way the nose of the cam drives the vented Opti. If you offset the cam sprocket, you change the position of the cam relative to the crank, and that means the Opti low resolution pulse signals are no longer correct relative to the crank rotation. With the unvented Opti, the cam sprocket drives the Opti via the splined shaft, so it has a different impact when you move the sprocket relative to the cam.
I moved my cam 2* over to *correct* it. He stated this would not be a problem, and my tuning was not adjusted for it.
Based on my results, I'd say he was correct.
When I degreed my cam, I found it to be 2* retarded so I installed a 2* offset crankshaft sprocket key which brought the cam timing spot on. And, just as Javier said, PCMforless agreed that this was the proper method to correct the cam timing.
Cam Timing Issue
As an experiment, I tried the following timing sets on my LE2.2 setup. The experiment was to see if the inconsistency was in the cam grinds, the timing sets or both;
$68 GM Racing Single .220 roller chain - dead on
$90 Jegs Billet double roller w/torrington - 3Deg retarded
$34 Cloyes Street Roller - 4Deg Retarded
$40 Stock GM Vortec Roller - dead on
$105 ProGear Billet/Heat treated/black Oxide Coated .250 Single Roller - 6 Deg Retarded. (nicest looking/fitting piece BTW)
Moral of the story: Degree your camshaft, I used the crank gear to dial mine in. We had no issues tuning it afterwards either.
*CompCams website is one source for directions*
On the Pro Gear did you make sure it was on the correct keyway on the crank gear? I've switched to these because I have never had one off when all the other ones are off.
The cams can be ground with the correct ICL in them and usually when you check the timing the part that is off is the timing chain, NOT the cam.
Degreeing the cam is doing it right, it's more to check that the install, cam and TIMING chain are correct. There is tolerance stacking in ° here so it's very easy for something to be off.
Bret
Bret
Feedback.
Travis
