Camshaft Install$$$$
Old May 22, 2003 | 05:14 PM
Fastrthnu's Avatar
Question Camshaft Install$$$$
On an average, those of you whom have had a cam installed...how much should it cost...for the install itself??? While I'm at it, what are some of the better cams for the Lt1's??? Thanks Jason
Old May 22, 2003 | 05:41 PM
pennys58's Avatar
From the shop, it can be very expensive. The install on my new engine, bought from a friend, cost him $900 and that was from a performance shop with all receipts. Depending on how much you want or need there are several different options. If you want a Hot Cam kit you can get them from Jason Cromer for around $500 and that is everything you need. Or you can get a custom kit from combination motorsports tailored to what you want. I believe the CC305, hot cam, and 224/230 all pass emissions. If that isn't a concern then a CC306 or a 230/236 are great cams for beafier applications. The whole kits would run you anywhere from ~$500-$700. If you knew someone to install it or found someone on the board to do it, it would be cheaper. I heard it is a 4-6hr. job and if they work for ~$50 then it wouldn't be too bad.
JOHN
Nov 18, 2023 07:21 PM
MadMav
May 25, 2015 09:35 PM
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
