Cammed LT1 Trapping <95 - HELP
Old Jul 19, 2004 | 10:04 AM
  #31
atljar's Avatar
Re: Cammed LT1 Trapping <95 - HELP
I had similiar issues with my car when i did my cam. Went to the track and i was 4-5 mph slower than when i had the stock cam.
I had little vacuum (ie brakes sucked), to get the car moving from a stop took lots of pedal, and it ran hot most of the time.
Cause.... Timing chain off a tooth and the dots werent lined up, even though i checked the stupid thing a few times. Shrug. it can happen to anyone.
I would grab a vacuum gauge and go from there. Re adjust the rockers and see how that affects the readings. If they are still low, go back into the cam and check the physical timing of it. Good news is that to do that you just need to tear down the front half of the motor, not the top half too
Old Jul 19, 2004 | 10:22 AM
  #32
atljar's Avatar
I just went back and searched a few of my old threads. Maybe something in here will help you too.
http://web.camaross.com/forums/showt...hlight=big+cam
Also forgot, my car liked to backfire through the intake when the timing was off
Old Jul 19, 2004 | 10:54 AM
  #33
Valkyn71's Avatar
I guess i am running your old LT4 ED timing set Atljar, maybe its cursed
Old Jul 19, 2004 | 11:21 AM
  #34
DrewHMS97SS's Avatar
i had a problem with the lt4 timing set from day one. when i installed it the chain was a loose bitch. im talking about 1/2 of play on both sides. that will kill performance. i got an oversized timing gear from wayne gray (wgray@cloyes.com) for the set and was very impressed. the gear took ALL the slack out. ($%#ing GM and their BULL $#% god damned POS timing sets.)
Old Jul 19, 2004 | 04:46 PM
  #35
atljar's Avatar
lol that set wasnt the one that got installed wrong. It was a little looser than i would idealy like, but the ability to keep your stock h20 pump was nice, and it was still a much better chain the the stocker.
Old Jul 19, 2004 | 05:09 PM
  #36
lifbcracker's Avatar
I have the same cam, i hope i dont run that at the track. Something must be wrong, my car seems pretty strong. A little sloggish down low but its running super rich and it needs another tune, but it feels hella stronger compared to the stock form which i managed to pull a 13.6 at 104. I would check over some things
Old Jul 19, 2004 | 05:54 PM
  #37
Valkyn71's Avatar
It seemed plenty tight when i installed it. It looked like the dots were lined up fine, but i didnt turn the engine over and double check
Old Jul 19, 2004 | 08:52 PM
  #38
the dots should be right over eachother, no questions. did you do the valve timing when the front of the motor was off.
Old Jul 19, 2004 | 08:59 PM
  #39
Valkyn71's Avatar
The first time i lashed the valves i had the engine apart, but i have done it a couple times since with just the valve covers off.
Old Jul 20, 2004 | 12:23 AM
  #40
have you had much luck with the new 0 lash?
Old Jul 20, 2004 | 08:56 AM
  #41
Valkyn71's Avatar
I havent relashed them yet...the car is getting ready to come apart for heads and a new cam, maybe i will relash them once to see if thats my problem.
Old Jul 20, 2004 | 10:26 AM
  #42
how long would it take you?
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Nov 20, 2014 06:03 PM
