Cammed LT1 Trapping <95 - HELP
Old Jul 17, 2004 | 10:40 PM
  #16
CeeBee94Z's Avatar
Originally posted by Valkyn71
Im running a 1/4 turn on my Comp Rs, that may be my problem.
Yup that is definitely at least part of your problem without a doubt. I am running a little less than 1/8 of a turn and I am worried that is too much. Re do it to slighlty past zero lash and go from there.
Old Jul 18, 2004 | 03:22 AM
  #17
S8ER95Z's Avatar
OUCH... oh and not to make it worse for you... my A4 3:23 95Z with 74K on the clock and a slipping trans.. pulled off 14.1 @ 97mph with a 2.1 60ft. .. So your mph isnt even close to stock lt1 mph (should be around 100+/- for an M6)
Good luck!!!
Old Jul 18, 2004 | 10:18 AM
  #18
TigerWoodsJr's Avatar
yeah...hopefully the valves are too tight...while his ET is suffering from the driving, his trap time shouldn't lose more than 2 mph or so with slow shifts....something isn't right ;[
Old Jul 18, 2004 | 10:35 AM
  #19
Valkyn71's Avatar
What happens when my lifters are adjusted too tight? Valves hanging open or what?
Old Jul 18, 2004 | 11:26 AM
  #20
TenaciousZ's Avatar
i'm pretty sure your valves won't close and you'll lose compression. I had that problem when I took my car up to the track, Hot and humid and pulled a 13.6 @ 103ish. That was also on 1.5 rockers.
Old Jul 18, 2004 | 12:21 PM
  #21
Dave88LX's Avatar
What are you shifting at?
You don't need ET streets to get your MPH up. I hit 100.06 MPH on Pep boys tires BONE STOCK untouched car.
Old Jul 18, 2004 | 04:58 PM
  #22
Valkyn71's Avatar
Re: Cammed LT1 Trapping <95 - HELP
Im shifting at 6100, tho i hardly need to shift out of 3rd.
Old Jul 19, 2004 | 12:09 AM
  #23
1982z28with18s's Avatar
Yes your car isn't running right, and give the man a break on his 60fts. He has a very grabby clutch and street tires and a track with NO PREP. I don't think I've ever seen a sub 2.0 60ft on street tires from a fbody before at this track. Most fbodies with street tires pull 2.1-2.2's at this track. Anyway, I have a datalog of his car that I'll post up tomorrow, wot tuning didn't look bad, but he doesn't have any part throttle tuning or it at least appeared that way. He was getting a few degrees of knock retard randomly but nothing bad. Hopefully setting it to zero lash will pick him up a lot. It was hot out but he should still be trapping around 105-108.
Old Jul 19, 2004 | 02:33 AM
  #24
1racerdude's Avatar
Any retard is bad.Put a resistor in line and stop the thing from pulling timing.Valve adjustment will kill it too.2.0-2.1 is not a bad 60" for a stock clutch and street tires.It takes a lot of practice to get one set up like that out of the hole.
Old Jul 19, 2004 | 02:39 AM
  #25
He might be losing 2mph at most from the retard. Most 6 speed guys pull 2.2's-2.4's on street tires, and the auto's are the ones pulling 2.1's on street tires.
Old Jul 19, 2004 | 02:45 AM
  #26
disco192's Avatar
Id say heat up the engine... give it about 30 mins and then pull the valvecovers and re-set the rockers to zero lash. Have some rags handy to keep the heat off. Get a set of nittos or BFG DR's and get your 60's down. That clutch is HARD to launch right. If you are worried about the rear end, get a TA girdle and it should hold up a little more.
Old Jul 19, 2004 | 02:46 AM
  #27
1racerdude's Avatar
Well thats 2MPH you shouldn't be giving up.Fix the thing.
Old Jul 19, 2004 | 02:56 AM
  #28
TobyZ28's Avatar
My bet is Valves + Reprogramming are the culprit... Valves once adjusted right should help out a lot!
Old Jul 19, 2004 | 03:07 AM
  #29
1racerdude's Avatar
Probably,but false knock from exhaust or valve noise will slow you down more than you think.You can get an LT-4 KM but probably wind up puting the resistor in anyway to eliminate it.He can do a search and go to radio shack and get one with 2 butt conectors and get rid of that problem.Set it on kill and drive it like you stole it is the way to go fast.
Old Jul 19, 2004 | 09:06 AM
  #30
Javier97Z28's Avatar
Moderator
ET streets + Spec IV + 10 bolt = kablammo
Im not expecting 12s but i know i should be alot quicker than mid 15s
Um, yah you should be expecting 12's. I'm running low 12's with basically the same setup, except an A4. Even in ****ty weather I'm in the mid 12's.
