Came across an interesting tidbit of info
Old Jun 10, 2007 | 05:48 PM
  #16
thesoundandthefury's Avatar
Originally Posted by crazydavez28
doesn't changing the ratio of the rockers increase the duration a little bit?
i mean duration measured at .050" with 1.6/1.7's would actually be greater than that of 1.5's
That is correct.
Old Jun 11, 2007 | 10:26 AM
  #17
JAKEJR's Avatar
Yep. The number I see most often is a 2/3 degree increase in effective duration. That increase is always associated with a one ratio change though.
So if you happen to move TWO ratios - like moving from 1.5s to 1.7s - would the effective duration double? If so, we'd be talking 4/6 degrees. Ponder, ponder, . . .
Jake
Old Jun 11, 2007 | 11:13 PM
  #18
crazydavez28's Avatar
i guess it would really depend on the grind of the cam and the contour of the lobe.
the higher ratio would defintely increase the rate at which the valve opens and that may have some benefits ... however it would also increase the stress on all your valvetrain components.
canbaufo
May 17, 2015 10:35 AM
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
jayblev95
Jan 6, 2015 11:52 AM
