Came across an interesting tidbit of info
So if you happen to move TWO ratios - like moving from 1.5s to 1.7s - would the effective duration double? If so, we'd be talking 4/6 degrees. Ponder, ponder, . . .
Jake
i guess it would really depend on the grind of the cam and the contour of the lobe.
the higher ratio would defintely increase the rate at which the valve opens and that may have some benefits ... however it would also increase the stress on all your valvetrain components.
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
