SA Vs NSA Rockers
Old Apr 13, 2007 | 11:04 PM
RyanD's Avatar
SA Vs NSA Rockers
How can you tell a difference by looking at them?
Old Apr 13, 2007 | 11:14 PM
SAs have little protrusions on either side of the surface that contacts the tip of the valve stem. NSAs do not.
Old Apr 14, 2007 | 09:52 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
Besides the guide, whats the functional difference? If doing a rocker swap is there any reason not to get guides and be done with the SA?
David
Old Apr 14, 2007 | 10:21 AM
neversummer's Avatar
AFAIK, the NSA's are safer for higher revving engines. The thought is that the tabs on the SA's could snap or break off. I've seen them, and they do look small. Anyway if you do go NSA, I've read that GM guideplates = correct and COMP = not correct. And you need hardened pushrods.
Old Apr 14, 2007 | 10:55 AM
CrazyLT1's Avatar
If you get NSA with GM guideplates and hardened pushrods - then you will not have anything to worry about for any application...
Old Apr 14, 2007 | 12:18 PM
RyanD's Avatar
gotcha
Old Jun 11, 2007 | 09:24 PM
Nitelite's Avatar
So it's probably best to just always run NSA rockers?
Old Jun 11, 2007 | 09:39 PM
Dan Parker '96's Avatar
That GM .vs Comp guide plate is crap. They both are a little off. But either is probably OK for 7K.
Old Jun 11, 2007 | 11:13 PM
2000GTP's Avatar
It depends, if the rockers are a stand-alone mod or you are just running a very mild cammed setup, then the SA rockers would be perfectly fine.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
