Cam? what else?
Old Jul 6, 2007 | 04:01 PM
NemesisLT1's Avatar
Cam? what else?
I am looking at cams soon, I found Comp Cams XFI LT1 Camshaft, 218 / 224, .570 / .565 113 LSA - says its got a strong midrange, good low end, and works good with computer tune, headers, and what not....
my question is what kind of other stuff do I need? springs/retainers/locks/pushrods?
what kind do you guys suggest with this particular cam, and do you suggest getting heads first?
Old Jul 6, 2007 | 06:36 PM
NemesisLT1's Avatar
after reading about springs I think ill go with PAC 1218s or 1518s.....
are retainers, locks, and pushrods required during this process?
also ive asked before but are the proform 1.6RR any good?
Old Jul 6, 2007 | 11:47 PM
2QUIK6's Avatar
Check ou this thread I started inquiring about that cam
http://web.camaross.com/forums/showthread.php?t=522974
I decided the idle was still a little radical for my wife to handle so I went with a LPE211/219, but I'd still like to get this cam for something else.
For the PAC1218 or 1518s, they need the same locks/retainers/seats as the comps
795-16 retainers
611-16 locks
4705-16 seats
Old Jul 7, 2007 | 03:41 AM
OrbitalChris's Avatar
valve springs, lifters, rocker arms, you dont have to do the heads, but theyll help
Old Jul 7, 2007 | 10:22 AM
2QUIK6's Avatar
Oh yeah, you'll also need to get a pushrod length checker and measure for proper pr length, if you don't know how to do that, its not that hard, just takes a little time, do a search and you'll find the process..do it with the car off, cranking it by hand. Don't take anyones advice on what length to get..too many variables..if someone is telling you a length, its because their own setup may not be correct and not have the proper geometry. Normally will be in the 7.1 to 7.25 range.
Old Jul 7, 2007 | 12:52 PM
2000GTP's Avatar
I would throw in a fresh timing set as well.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
