Cam suggestions...
Old Feb 25, 2007 | 06:57 PM
  #16
mdacton's Avatar
you don't need to take the heads off to put springs on....
Old Feb 25, 2007 | 07:00 PM
  #17
Meen95z's Avatar
So I need new springs? And is there any other springs I can just swap out besides those very expensive beehives?
Old Feb 25, 2007 | 07:04 PM
  #18
mdacton's Avatar
they are your best bet....anything else is not going to be great for the street and will wear out
I have k-motin 750's....but I had that for other reasons
Old Feb 25, 2007 | 07:07 PM
  #19
buzz12586's Avatar
Hey if you just want to run as fast as a bolt-on LT1 don't change out your springs.
Old Feb 26, 2007 | 02:53 PM
  #20
Z-RATED94's Avatar
Originally Posted by mdacton
them springs aren't very good.....you may want to check them
I'll second that. You probably need a better set of springs.
Old Feb 26, 2007 | 09:50 PM
  #21
SStrokerAce's Avatar
When the hell did beehives become expensive? Maybe it's just me living in my world where I pay $400 a set for springs all day long, but beehives ARE NOT expensive. Considering they last longer and work better than other stuff out there.
Bret
Old Feb 27, 2007 | 06:58 AM
  #22
Z-RATED94's Avatar
Just get the beehives, even if they are a little pricey. They are well worth the money. And make sure you check the installed height.
I have to ask, whos converter are you running and why only a 2400 stall? If your trying to be quick in the 1/4 mile I would think you should have at least something in the 3200 to 3600 range. Some guys would even go bigger than that.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
