Cam and springs recommendations
Old Dec 20, 2007 | 08:24 AM
lt1loudmouth07
Guest
Posts: n/a
What is a good cam and valve springs to put in my 95 camaro z28 the only mods i have done to my car is 342's and headers off road y and flowmaster exhaust and tune from madz28. I want something that sounds aggresive can someone please tell me what all i need to do this
Old Dec 20, 2007 | 10:07 AM
Guest47904's Avatar
Guest
The hot cam is a great starting cam set up...
This has always been a great starter cam.
http://store.summitracing.com/partde...2&autoview=sku
Need these too:
http://store.summitracing.com/partde...6&autoview=sku
http://store.summitracing.com/partde...G&autoview=sku
Good idea to change the rest of the coolant at the time, the thermostat, hoses and belts too if you haven't already done so.
Old Dec 20, 2007 | 10:19 AM
The Engineer's Avatar
The GM hot-cam kit is a great performance option for a bolt-on engine! When I was doing bolt-ons, my car went a 12.42 with the hot cam kit, headers, stall and 3.73s.
WD
Old Dec 20, 2007 | 10:57 AM
rskrause's Avatar
Moderator
HOT cam kit is a great value as well.
Rich
Old Dec 20, 2007 | 04:38 PM
BIG_T's Avatar
i would go with something bigger than the hotcam. most people wish they would have went bigger after the install.
Old Dec 20, 2007 | 05:07 PM
Guest47904's Avatar
Guest
Bigger, faster, longer, louder and few more er's I probably don't know are not the answer. Just going to the bottom of the cam page is not the answer. Everything from the heads (ports, valve sizes, quench area and chamber volumn) to cylinder volumn to intake runners, to converter stall to rear end gears all work in concert.
Not to mention road manners and the ability to idle. Much less tune. Study, study and then study some more before you start throwing money around. But if you got some to waste, send some my way.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
