removing engine from bottom
Old Dec 20, 2007 | 01:26 PM
steve40's Avatar
few questions
where do you guys disconnect the brake lines at?
do you remove the entire suspension or disconnect the upper ball joint and drop the shock
thanks
Old Dec 20, 2007 | 02:04 PM
brubaker's Avatar
You disconnect two of the three brake lines at the abs control unit that are going down the left strut tower. one of the lines is larger than the other two, that one is for the rear brakes. at least thats the was it is on a 94. some newer ones might have one line per wheel. as far as the upper control arms you only need to remove the four strut tower bolts on both sides.
Old Dec 20, 2007 | 02:05 PM
I remove the front brake lines at the ABS unit. It will take a little bit of fishing/tweaking to get them free as you go down.
Take the bolts out of the top of the shock tower and everything below drops out with the k-member. I left my wheels on.
Old Dec 20, 2007 | 05:17 PM
RKPsk8er's Avatar
where can I find a GOOD write-up for engine removal out the bottom. I'm pulling mine soon and I'd like somewhat of a detailed guide. THANKS
Old Dec 20, 2007 | 05:53 PM
steve40's Avatar
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
DirtyDaveW
Dec 1, 2016 05:37 PM
sscott
Jan 17, 2015 04:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
