Cam Shaft Swap
Old May 1, 2003 | 09:21 PM
TransAm9585's Avatar
Question Cam Shaft Swap
Is it possible to do a cam swap on a 4th gen TA with the motor still in the car. Has anyone done this or had this done to there vehical and how much did it run. Thanks for the information guys.
Old May 1, 2003 | 09:38 PM
BOWTYDE's Avatar
I did it in my camaro. I don't think the frame and all that is the different in the camaro then the TA. It worked fine.
Old May 1, 2003 | 09:39 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
yup, I did it on another board member's TA
just pull the radiator/ac stuff. plenty of room in there.
there are a few guildes out there.
main things are
dont drop a valve
make sure the opti is flush BEFORE you torque down the bolts
if you are resuing the opti- drain/force the coolant out of the car first. other wise it will pout on the poor opti.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Victor Lamb
Aug 26, 2017 02:52 PM
jj_burchiel
Mar 5, 2015 07:05 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
Nostang 96z
Sep 14, 2002 08:22 PM
