Cam set-up for 383 Stroker LT1
Old Oct 12, 2006 | 06:47 PM
Transamman25's Avatar
After installing this cam in my stroker .. im not so impressed anyone used the Comp Cams LT1 276HR-14 in there projects ??
.510 intake / .510 exhaust
276 Intake / 290 Exhaust
LSA 114
This cam seems too small .. any ideas .. anyone else ?
Old Oct 12, 2006 | 06:55 PM
LTBlackBird's Avatar
Re: Cam set-up for 383 Stroker LT1
Too small?
Old Oct 12, 2006 | 07:11 PM
jerminator96's Avatar
That cam does seem a bit small, what ratio rocker arms are those lift numbers calculated with (if any). What kind of heads are you using, and who suggested the cam?
Edit: Probably should ask some other questions.
Are you going N/A of FI? What are your power goals? Track or street car? What don't you like about the cam?
Old Oct 12, 2006 | 10:54 PM
chrism400's Avatar
It is definitely not too big! I'll tell you this though, it will be a tire shredder! Are you looking for a really torquey setup that peaks at about 5300 in a 383? That's what you've got. I personally know a guy here in Dayton that built a home ported iron headed LT1 383 11 to 1 in an ImpalaSS that ran 11.81 at Cecil with the Comp 501 cam and 1.5 rockers. That's a 212/218 cam. What you will have is a great all around motor that would be happy with 3.42's and a 2800 stall.
Old Oct 12, 2006 | 11:02 PM
SS RRR's Avatar
LSA 114
What are you looking for performance wise? What made you decide on that cam?
Old Oct 12, 2006 | 11:06 PM
SS RRR's Avatar
Originally Posted by LTBlackBird
Too small?
i believe the duration numbers are advertised and not @ .050
Old Oct 12, 2006 | 11:30 PM
That's close to what I am running in my mostly stock engine (if those are not .050 duration numbers).
Old Oct 13, 2006 | 12:52 AM
SS RRR's Avatar
Here's the specs
http://www.atlanticspeed.com/product...t=1326#details
Unless you are worried about emissions that is a pretty dinky cam.
Old Oct 13, 2006 | 02:58 PM
The cam is at .050 its 220/230 .... to say the least it was reccomended by the speed shop here in Memphis, Saying .. Man this thing will Really open up your Stroker - I need a 96 T/A that can run a 11.99 Pass .. Before i spray Its a M6 car Has every bolt on under the sun with mild Head Porting Centerforce clutch and 3.42's Comp 1.6 Rockers
Old Oct 15, 2006 | 10:40 PM
Anyone ?
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
