What makes my idle higher when I first start it?
Old Oct 15, 2006 | 07:26 PM
FullCustom67's Avatar
I've noticed more times than not that my idle is kinda low on start up. When I had my 94 everytime I would start it it would Idle abit higher for about a min or so and then came down after the engine came to temp. what sensor woud make the car idle correctly. almost seems like it wants to stall out at idle when it's cold.
Thanks Ya'll
Old Oct 15, 2006 | 08:15 PM
Dave89IROC's Avatar
Re: What makes my idle higher when I first start it?
Thanks Ya'll
probably a sticky/dirty/faulty IAC
Old Oct 15, 2006 | 11:13 PM
The PCM sets the idle speed based on coolant temperature, and using the IAC valve as noted in the post above. Could be a faulty coolant temp sensor (the one in the water pump housing) or the IAC as noted above.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
Dave19yz28
Jan 26, 2003 01:45 PM
