Cam selection
Old Jul 10, 2008 | 04:42 PM
texas97z's Avatar
Cam selection
Ok. I have mods in sig and am looking to now go to a better cam in the near future. I like the way the 847 looks based on some threads, and the fact that I like to stay all GM when possible, I bought this engine used before I get picked apart for that comment. But at the same point I don't want to rev to the sky either. I would like to shift no higher than 6500 and would actually like around 6,100(just a comfort thing). If the 847 will get this done and make more power than I am sold, but I am getting conflicting info on here about a good shift point for a 383 with this cam. Ultimately I want the sound and the power of a better cam.
Thanks as always.
Old Jul 10, 2008 | 07:05 PM
truedualws6's Avatar
If you want to stay GM the go with an 846 if you are planning on shifting at 6,100.
Old Jul 10, 2008 | 08:43 PM
dre2013's Avatar
in that 383 i would go with the gm847,cc306, or a custom cam
Old Jul 11, 2008 | 08:19 AM
seawolf06's Avatar
For a 383 and 6,100 RPM, get Lunati 60122 Voodoo cam. It says 2400-6200RPM, but that will drop with a larger cube motor.
http://getonitracing.net/forum/viewtopic.php?t=376
EDIT: Get one of the BRE cams in the for sale section!
Old Jul 11, 2008 | 08:32 AM
slomarao's Avatar
if you want to stay gm go 846/7.
Old Jul 11, 2008 | 08:34 AM
seawolf06's Avatar
The GM cams are very old technology, IMO. You are leaving a lot on the table by going with the 846/857 cams.
Old Sep 19, 2008 | 12:07 PM
texas97z's Avatar
Well it took a while but I bought the 847 cam and threw wanting to shift at 6,100 out the window. Before I install I had a quick stupid question. I am not going to have any clearance issue because of the stroker am I? I have seen this cam in many 383's on here but none state if it is a small base circle cam or factory grind. Any advise?
Old Sep 30, 2008 | 02:32 PM
texas97z's Avatar
I saw one thread where the guy was having clearance issuse, but he had the entire engine out. I am not wanting to pull the engine put would like to know before I start the swap if I am going to hit. Already a 383 now and I am not hitting anything currently. Please advise.
Old Sep 30, 2008 | 03:09 PM
slomarao's Avatar
gm 847. Shift it a tad early. You wont leave much on the table than.
Old Sep 30, 2008 | 03:21 PM
seawolf06's Avatar
Call Crane and make sure it's a small base circle cam. I don't what you can do other than that.
Old Sep 30, 2008 | 03:37 PM
texas97z's Avatar
I am not seeing how calling Crane would help on if the GM cam will hit? Am I missing something?
Old Sep 30, 2008 | 03:42 PM
seawolf06's Avatar
Crane makes the GM847 last I heard.
Old Sep 30, 2008 | 03:52 PM
texas97z's Avatar
oh, ok. Wasn't sure who was doing the grinds. Thanks for the advice.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dec 17, 2014 11:00 AM
Black Sunshine/ 00SS
Jul 29, 2002 11:57 PM
