Cam Selection
Cam Selection
Comp Cams recomends 07-467-8 (230/236), but he didnt really ask much about the car. he was in a hurry.. pfff
I feel like that a little weak. WHat do you think
95 Camaro Z28
383 Stroker
Stock Heads (Soon To Be Porter)
Stock Intake Manifold (Soon to be ported or replaced)
SLP INtake
Pacesetter Headers
No cat
Flowmaster Cat Back 80 series
LT4 Hydrolic Roller lifters
LT4 1.6 Roller Rockers
NO EMISSIONS TEST
No EGR
MSD Vented Opti
MSD Coil
I looked at the description of this cam and it says strong idle?.. I want a bumpy idle. also, do I NEED to replace the valve springs with the cam?
95 Camaro Z28
383 Stroker
SLP INtake
Pacesetter Headers
No cat
NO EMISSIONS TEST
No EGR
MSD Vented Opti
MSD Coil
Here's my suggestions:
Since you're running a 383, Get an AI package like I did. They're the only people I swear by as far as Heads and Cams go. I had them do my intake porting as well. Excellent quality, and excellent people to do business with period. You will not be dissapointed. You're going to want some bad mammer jammers for heads, then discuss with them about your needs for a cam (driving habits, etc.). They won't steer you wrong...
Good Cam Info on stock/mildly worked over heads if you decide to take the road most people do (for mild setups, budget constraints etc.):
http://ls1tech.com/forums/showthread.php?t=836200
Any cam worth swapping to will need new springs (assuming you are running the stockers). There are a lot of cam threads (too many). You might want to read some of them. There is not enough info in your post to make specific recommendations. The kind of info needed can be found here: http://www.kennedysdynotune.com/Cust...nformation.htm That's the kind of info you need to post to get a worthwhile answer to your question.
Rich
Rich
I've just put that cam in my 396. I can let you know this evening how it sounds. I didn't want to go real wild because 95% of the time is cruising and the other 5% is playing.
I've got that cam, LS7 lifters, TPIS 58mm throttle body, 36# injectors, pro magnum RR's, LE2 heads, Mahle -16cc pistons, Dragonslayer crank, and long tube headers. I used the Cloyes roller timing chain and did away with the water pump.
wow, 1963 nice.. do tell me how that sounds.
as for springs. im not running stock. im running the springs from the LT4 hot cam kit. are those good enuff to keep on? EDIT: found my answer: "The LT4 valve springs located in the LT4 "hot cam" kit should NOT be considered to be run with any cam due to the fact they are known to be very weak and only have a max lift rating of .540 which is not high enough for most off the-shelf camshafts".. so I guess i will be purchasing valve springs and keepers and shims and seals..
Type of cam (check)
Solid flat tappet:___ Solid roller:___
Hydraulic flat tappet: ___ Hydraulic roller: _X_
Primary Usage (check)
Street performance: ___ Street/strip: _X_
Drag race: ___ Oval track: ___
Marine endurance: ___ Marine drag: ___
Pulling: ___ Road race: ___
Vehicle Information:
Weight:3500 Transmission: 6 Speed Manual
Rear end ratio: 3.42 Max RPM: 6850
Fuel: Gasoline 93 Octaine Ignition: MSD OptiSpark MSD Coil
Nitrous: Yes Nitrous HP: 100-150
Roots blower: No Boost: n/a
Centrifugal SC: N Boost: n/a
Turbo: No Boost: n/a
Rocker ratio (OHV engines): 1.6RR Compression ratio: 10.6:1
Intake valve diameter: 1.940 Exhaust valve diameter: 1.50
Cylinder head used: Stock Ported: Yes (Will Be Soon)
Carbureted: N0 Carburetor brand/CFM: n/a
Fuel injected: Yes Throttle body size: 58MM (soon)
Intake manifold: Stock LT1 Ported
Type of cam (check)
You will most likely also need new rockers and pushrods if you want a cam that aggressive. The 383 can handle a larger cam, but your compression is almost stock, so a large cam would drop your DCR too low I would think. I can't remember if the longer stroke makes up for that or not.
If all you want is a lopey idle, then get a GM847 or CC306. If you want better performance, then read up on DCR, overlap and valve timing events to see what is best for you. Chances are you will have to wait until your heads are ported to pick out a cam. They will affect your SCR and DCR. You should try to get it around 11:1 I would think, especially if you want to use nitrous.
The added info is helpful. I would look for ~225 degrees @ 50 on the intake with ~6-10 degrees more on the exhaust with a 112 degree LSA. Look for ~.550-.575" lift. This is pretty close to the GM 847 but a bit smaller. If your CR were higher you could use a little biggger cam. It will need tuning to run right and (obviously) the correct springs.
Rich
Rich
yea. I was playing with CamQuest and more compression really added alot of power.
I will definatly be shooting for more compression when I get new heads
How much is to much compression. I know when I start knocking bad its so much, but when it that?
Thanks for the comments. Got it started today
and after pulling the pan twice to correct rod bolt clanging on tin it ran like a dream. The idle is perfect for me. It has plenty of lope, chop whatever it's called nowdays.
I have no plans for FI. I have 53cc heads and a .028 head gasket off an Impala. The block was decked and the pistons are .010 in the hole. That is about 11.18/1 compression ratio. That's all I wanted. It revs a lot faster and feel like a turbine at speed.
Sounds like a nice set-up...just curious as to why you chose -16cc pistons though?
IMO, the cam is one of the last things you select when building a motor. It can be controlled more precisely and you have more variables to play with. If your block is already finished, then you can only use the heads and head gaskets to change your compression, both of which have their limitations from other factors. However, once you know your compression, you can calculate your DCR with different cams.
I have already purchased the crank, rods, pistons, rings, and bearings. The pistons I chose were Federal-Mogul Speed-Pro that will yeild these compression ratios: 10.6:1 with 58 cc head, 9.7:1 compression with 64cc head or 9:1 with a 72 cc head. Dome Shape; .110 Dish; 2 valve reliefs, Compression dist 1.425 , Deck Clearance .025, Skirt Clearance .0010.
I will be using stock heads for atleast 3 months then I will move on to trickflow or LE2 heads. at that time I will get the intake manifold ported to accept a 58MM throttle body.
Dec 17, 2014 11:00 AM
