Cam selection
Old May 9, 2005 | 09:06 PM
94NDTA's Avatar
Cam selection
I need help choosing a cam, or being pointed to someone who can grind me one. This will be on unported stock heads. The car has 3.23 gears, 2800 converter (2.2STR),and a 100-150 shot. I am aiming for 340ish rwhp without spinning past 6400 rpms. Thank you!
EDIT: stock bottom end and stock rear end (rear may be changed soon)
Old May 9, 2005 | 09:15 PM
SStrokerAce's Avatar
Re: Cam selection
MadWolf has a great post on cam selection
http://web.camaross.com/forums/showthread.php?t=356916
Then there are the guys who go custom
http://web.camaross.com/forums/showthread.php?t=259094
Old May 9, 2005 | 09:18 PM
94NDTA's Avatar
Re: Cam selection
first link doesn't work. Any links to the cam grinder in the second thread? Any idea how much a custom cam like the one in the second thread would cost.
Old May 9, 2005 | 09:40 PM
89385formula's Avatar
Re: Cam selection
SStrokerAce is the cam designer. PM him....he's the man. Do a search and you find a ton of posts about his work. I personally have gotten a chance to work with him, and he is a very good guy. You won't be dissappointed if you chose him to do a cam for you.
Old May 9, 2005 | 09:44 PM
Robs97Z28's Avatar
Re: Cam selection
yeah, he also grinds Lloyd cams, too. Brett knows his stuff. He is the person I would call.
Old May 9, 2005 | 09:54 PM
Re: Cam selection
Yeah that's me but I don't push things around here just share what happy people have to say...
I fixed that link in the first post.
Old May 9, 2005 | 10:03 PM
ChrisUlrich's Avatar
Re: Cam selection
But couldn't you get a 847 on a 114lsa to bring down the power band? Or something like that with the CC306?
Old May 9, 2005 | 10:09 PM
94NDTA's Avatar
Re: Cam selection
From what I read, those seem too big. I don't want to spin it too high becuase I will be running a larger shot of N20. The 350rwhp peaking at 6400 rpms seems perfect for me.
Old May 9, 2005 | 10:14 PM
Re: Cam selection
A 847 on a 114LSA would make power HIGHER and make less power.
Old May 9, 2005 | 10:24 PM
Re: Cam selection
Dave from cms told me to use the 114lsa because I wanted to shift at 6k because of the stock bottom end... he said using a 112lsa would defeat the purpose because of the earlier shifts... so I figured it would be the same with other cams.
Old May 9, 2005 | 10:35 PM
Robs97Z28's Avatar
Re: Cam selection
sounds like you are looking for a hot cam, cc305 or a stage 1 cam from Brett (this is the cam he does for Lloyds heads).
Old May 9, 2005 | 10:47 PM
Re: Cam selection
Chris,
Yeah I would say most LT cams that you see out there are way off. The LE2 cam is smaller in duration than a GM 847 cam but it peaks HP in the same 6400-6600range on ported heads and makes MORE midrange TQ. The one reason I keep cam specs "secrect" is because IMHO everything else is way off and seeing the specs on a good LT cam for ported heads might clue some of these guys in, in most cases it's not but in some cases this would be true. When someone says go to a higher LSA on this already big duration cam for a lower RPM range.... that scares me. You are moving the IVC (intake valve closing point) later, which will hurt dynamic compression, low end tq and you are taking the overlap out of the cam, all of those are not good things. I could write some really bad *** posts about what you want in a cam as far as specs go, but then again I'm fighting against my own pocket doing that. All guys really need to know is that this works and this doesn't......
As I've said before... Lloyd and I are getting these numbers with some pretty simple stuff. He's getting some really awesome ports in these heads that really move some wind and we are doing the right things in terms of cam specs and valvetrain.
Bret
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dec 17, 2014 11:00 AM
Black Sunshine/ 00SS
Jul 29, 2002 11:57 PM
