Cam Questions
Old Mar 11, 2007 | 08:47 PM
1slowbird's Avatar
Cam Questions
ok well i decided to go with the cc 503 cam....will the LT4 springs, locks ect work on this cam if i keep the stock 1.5 rockers???i think the lift on that cam is .503/.510, and the LT4 springs say there good untill .525/.525 so they should work right???
Old Mar 11, 2007 | 09:22 PM
96capricemgr's Avatar
The LT4 springs are marginal at best for the HOT cam and it achieves it's .525 lift with 1.6 rockers which are easier to control than had the lift been achieved by moving the heavy roller lifter as much. The lobes of the HOT cam are pretty mild too most aftermarket cams move the lifter more aggressively.
I am going to say no they will not work. If you try them though you know ahead of time what that "high rpm miss" is, it is called valve float.
Old Mar 11, 2007 | 09:25 PM
1slowbird's Avatar
thanks..do u know of springs that arent that expensive??
Old Mar 11, 2007 | 10:48 PM
1slowbird's Avatar
can some one give me a link to the cc 987's???
Old Mar 11, 2007 | 11:04 PM
seawolf06's Avatar
search here for the crane kit 10308 or something like that. Should work.
Old Mar 11, 2007 | 11:07 PM
mdacton's Avatar
Isky has a good spring set, they will do what you want but they run $300 for just the springs
Old Mar 11, 2007 | 11:12 PM
seawolf06's Avatar
He said inexpensive, otherwise I'd say get the comp 918's.
Old Mar 12, 2007 | 09:19 AM
2000GTP's Avatar
Comps will be the cheapest, check out the various supporting vendors on here, some of them have them.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
