Hot Cam questions..
Old Mar 11, 2007 | 03:10 PM
1slowbird's Avatar
Hot Cam questions..
ok here is the deal my car has been down for a while because of bad lifters..so i want to replace them wit oem and also put in a hot cam with lt4 springs ect., i also want to replace the timing chain...i know gaskets, but is ther anything else i would absloutly need to replace???and could i have links to the best deals on these please...im on a college budget....thanks for all tha help..
Old Mar 11, 2007 | 03:13 PM
Z95m6's Avatar
The only thing I would add to that would be a tune for your pcm. As far as places to get deals, I would check the for sale forum on this site. I'm sure it's saved me 1000's of dollars over the years.
Old Mar 11, 2007 | 03:37 PM
2000GTP's Avatar
I would spend a little extra money and go with some slightly stronger springs, especially if you are going to be doing 1.6 rockers along with the Hotcam.
Old Mar 11, 2007 | 03:46 PM
danhr's Avatar
I keep hearing that.... somone clarify this for me....
the max lift on the lt4 springs are .550 from what I read... hotcam with 1.6 rockers is .525 lift...
the lt4 "kit" comes with lt4 springs and 1.6 rockers...
why do so many people recomment to get better springs w/ the hotcam?
Old Mar 11, 2007 | 03:52 PM
1slowbird's Avatar
i dont plan on runnin tha 1.6s...jus doin tha cam, springs, lifters, timing chain, LTs, and a tune..but i was lookin in summit and found some lifters that say 1987 up oem roller lifters for like $120..would these work on mine???
Old Mar 11, 2007 | 04:14 PM
Z95m6's Avatar
Yeah those lifters should work fine. You won't need some high dollar lifters for your setup. You might look at picking up a hot cam kit as you can get the whole kit pretty cheap and get some 1.6's roller rockers with it. They should add a good 10rwhp to the setup.
Old Mar 11, 2007 | 04:18 PM
danhr's Avatar
imho.. you're already going to be doing the valvetrain.... why not throw those on.... it's not that much extra money, and is one of the better bang for you buck mods
if you aren't going to be getting ur pcm tuned, i think it would be wiser to put the rockers on, instead of the cam.
Old Mar 11, 2007 | 04:21 PM
1slowbird's Avatar
yea ive been lookin at the hot cam kit...but i need lifters and timin chain..dont really need tha roller rockers...jus trin to get my car back on tha road with as least as posible..tired of drivin my v6 truck wit no power ...thanks for tha help...
Old Mar 11, 2007 | 04:25 PM
1slowbird's Avatar
i will be gettin a mail order tune...it will jus be a lil bit later...im on a college budget...jus thought while i had it tore down to put in a hot cam...and i heard u can run it with out a tune for a lil bit, it wont run good but it will run..
Old Mar 11, 2007 | 04:30 PM
Z95m6's Avatar
There are enough hotcam tunes floating around that i wouldn't buy one anyways. You can get near perfect hotcam tunes if you look around. You just need to find someone to flash your pcm for you.
Old Mar 11, 2007 | 04:37 PM
1slowbird's Avatar
k thanks...what all lil stuff other then springs retainers for the valve train??
Old Mar 11, 2007 | 04:56 PM
1slowbird's Avatar
also where can i get all the LT4 valve train parts??
Old Mar 11, 2007 | 06:13 PM
1slowbird's Avatar
anyone??
2000GTP's Avatar
Check out www.sdpc2000.com, they sell all that stuff.
Old Mar 11, 2007 | 07:01 PM
Heatmaker's Avatar
Advanced Member
just make sure you have the budget set for expensive sells and specialty tools that you may need.
I would look for the Hotcam kit... I think it comes with everything needed.... I think.
