Cam Question
Old Aug 20, 2012 | 02:12 PM
96LT1Z-28's Avatar
Cam Question
Hi all Im looking to put a cam in my car but I do not know which one will be the best for you I do race at my local track but I also daily drive my Camaro I would like a good choppy sounding one and its good for the street/strip I have a k and n cold air intake and I just put on a cat back exhaust from Texas speed and performance so I want to do a cam next then headers later I do plan on changing the springs when I switch out the cam Im just not sure which would be the best application for me any help is greatly appreciated Thanks in advanced
Old Aug 20, 2012 | 02:25 PM
6SpdLT1Z's Avatar
Re: Cam Question
You will need to swap out the valve springs because they can barely handle the lift of the stock cam/rockers.
I'd recommend getting headers first or putting them on when you do the cam swap. They are considered a supporting mod for cams.
Is your car an automatic or manual? You may need a stall/gears as well depending on what cam you're looking at.
As far as cam's go, what's your budget? There are plenty of mild cams with great drivability. Hotcam, cc503, etc.
**LT1 Camshaft/Valve Train Selection Guide** - LS1TECH
Old Aug 20, 2012 | 02:33 PM
96LT1Z-28's Avatar
Re: Cam Question
It's a 6speed manual I do plan on putting 3.90s in the rear that's plenty for down here and the cams I've seen on ws6 store are about 270 so that's cheap for me top of the budget Is 500 right now just kinda wanted the cam before the headers because I do all this my self but I think ill get the cam and then the headers and install at the same time and I do know about the springs also those will be swapped at the same time Thanks for the quick response also
Old Aug 20, 2012 | 04:31 PM
6SpdLT1Z's Avatar
Re: Cam Question
$500 isn't going to cover a cam swap IMO. Unless you get a good deal used.
At a high level you'll need:
- Cam
- Valve Springs
- Rockers
- Gasket Set (Intake, Valve Covers, Water Pump)
- Opti o-ring
- Oil change supplies
I'd highly recommend a mail order tune after your done, as well as replacing the timing chain while you're in there if you have higher mileage.
If you're strict on the budget, I'd look at the hotcam. It's perhaps the cheapest way to go unless you go used. Great sound, very drivable, and a noticable increase throughout the powerband. Others will argue because for a little more money you can get more power with other cam choices.
GM Performance 12480002 - Chevrolet Performance LT4 Hot Cam Hydraulic Roller Cam Kits - Overview - SummitRacing.com
Old Aug 20, 2012 | 04:42 PM
Re: Cam Question
You got some input on this topic about a year ago. Back then, you r were talking about a "stall converter"..... have you done a trans swap since then?
https://www.camaroz28.com/forums/lt1...estion-825231/
Old Aug 20, 2012 | 05:27 PM
96LT1Z-28's Avatar
Re: Cam Question
I don't mind buying parts here and there and yeah its been a long time since I've been to this site didn't do a trans swap I didn't know that a stall converter was for a automatic and I completely forgot at that thread sorry about making a new one about the same thing
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
