Cam question...
Old Oct 16, 2007 | 06:48 PM
RallyRed701/2's Avatar
Cam question...
You absolutely NEED new springs when you put in a new cam right.... ?
Old Oct 16, 2007 | 07:02 PM
speed_demon24's Avatar
Yes
Old Oct 16, 2007 | 07:14 PM
94Camaro_Z_28's Avatar
Yuppers.
HardcoreRM125's Avatar
Yep
Old Oct 16, 2007 | 07:39 PM
urbaNHunter44's Avatar
That's a big 10-4 good buddy!
Just stay away from the 918s
Old Oct 16, 2007 | 07:49 PM
seawolf06's Avatar
Don't forget to give yourself enough extra clearance as well. Don't get LT4 springs for a cc305 cam if they're just barely enough for it, for example. (I didn't even check the numbers, so don't critique it)
Old Oct 16, 2007 | 08:09 PM
liltxboi911's Avatar
i believe you're right, the LT4 springs are barely good enough for the LT4 hotcam (which is smaller than the cc305). some would even argue to ditch the lt4 springs all together, even for the hotcam.
Old Oct 16, 2007 | 08:10 PM
Irish350's Avatar
i would
Old Oct 16, 2007 | 08:14 PM
seawolf06's Avatar
They sell the stock LT4 springs with the hotcam, but the "hotcam" is not the stock LT4 cam. IMO, those springs are BARELY enough for that cam, even though the max lift is within specs. Get some beehives
Old Oct 16, 2007 | 11:34 PM
97WS6NY's Avatar
yes
I think beehives should just about be the only spirngs they sell for hydraulic roller cams. They work for damn near every application. everything from a hotcam to something like mine well over .600 lift (with 1.6RRs)
Old Oct 17, 2007 | 06:40 PM
so what would some decent behive springs be (that could handle up to .600 lift)?
Old Oct 17, 2007 | 10:58 PM
seawolf06's Avatar
PAC has two: 1218 and 1518. Check the sponsor section.
Old Oct 17, 2007 | 11:05 PM
rskrause's Avatar
Moderator
Originally Posted by 97WS6NY
yes
Just how did you decide this?
Rich
Old Oct 17, 2007 | 11:12 PM
^ Cause their popular with most off the shelf cams smaller than a GM847/CC306. They handle fast profiled lobes well.
Hahah honestly though you could probably school me on cams & valvetrain any day.
Old Oct 18, 2007 | 07:07 AM
rskrause's Avatar
Moderator
I guess my point is that this is not a new idea. It was popular a few decades ago and then went out of "style". Is it a fad again or will it last? Either way, the tapered springs do work. And the idea of keeping the moving mass low is attractive. But the hundreds of millions of sets of "regular" springs out there sem to work well too.
I would concentrate on the right seat and open pressures for the combination along with the correct installed height. If there is a tapered spring that meets the bill, it's a reasonable choice.
Rich
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
