CAM Question
Old Sep 6, 2003 | 07:30 PM
93ZM6Tally's Avatar
CAM Question
I'm currently running the CC305 cam and want to go with something more aggressive, (still streetable, daily driven). I'm also running Isky springs that are good to .550 lift. I also have 1.6 roller rockers. What would be a good cam that's more aggressive with this setup. Forgive me, I don't understand cam numbers very well.
The CC305 that I have is a 220/230 duration, .510/.510 lift with a 114LSA.
Thanks.
Old Sep 6, 2003 | 07:34 PM
93ZM6Tally's Avatar
BTW Heads have Been Ported and Polished by a local shop - no longer in business. Don't have good spec's on them.
Old Sep 6, 2003 | 07:41 PM
PoorMan's Avatar
230/236 X-treme energy cams by comp cams seem to be popular for M6 guys. I think the 224/230 is best for A4 guys w/ stock TC though. Both have various lift available. I think you will see about 15 hp increase.
Jeff D.
Old Sep 6, 2003 | 07:56 PM
93ZM6Tally's Avatar
What lift could I safely go with. Thats part of what I don't understand. The lifts that i've seen for the cams you talk about are shown with 1.5 rockers.
Old Sep 6, 2003 | 08:03 PM
93ZM6Tally's Avatar
c'mon Phil, Fred etc. I know you guys have nothing better to do than answer my ****** stupid questions!
Old Sep 6, 2003 | 08:21 PM
PoorMan's Avatar
http://www.cmotorsports.com/engine/l...ft-design.html
The cams here are shown with lifts using 1.6 rr's. Looks like u need to change springs if you do go with a bigger cam w/ 1.6 rr's.
Old Sep 6, 2003 | 08:25 PM
Z95m6's Avatar
if you don't want to change your springs then i think your in trouble. I believe even the smallest 230/236 will be too much lift with your 1.6's. I would get a whole new cam package from combo and try that 227/233 if i had it to do over again but that cam wasn't out when i needed one.
Old Sep 6, 2003 | 08:40 PM
12SCNDZ's Avatar
Um...What's wrong with the CC305? I went 12.38 @ 111.9 MPH last night with mine....With a full-weight '93 Z.
Frank
Old Sep 6, 2003 | 08:42 PM
93ZM6Tally's Avatar
CC305 was fine, just looking for a little more.
Old Sep 6, 2003 | 08:45 PM
PoorMan's Avatar
Their are some springs that cc makes that are drop ins. They do not require machining the head. I believe they are called "beehive" springs. They are good to .600 lift give or take depending on the install height.
Jeff D.
Old Sep 6, 2003 | 08:51 PM
93ZM6Tally's Avatar
Thanks Jeff, thats the kind of info I'm looking for. I really don't want to buy new springs but I'll probably do that. I absolutely don't have the budget or time to wait for machine work right now.
Old Sep 6, 2003 | 09:05 PM
93ZM6Tally's Avatar
I'm never satisfied. Is it possible to change the springs without removing the heads?
Old Sep 6, 2003 | 09:34 PM
93ZM6Tally's Avatar
Just found the info about removing valve springs on Shoes site. As usual you are "Da Man" thanks again guys.
Old Sep 6, 2003 | 10:11 PM
nateh's Avatar
It is possible to change the springs without removing the heads. You just need the right spring compressor.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
