Shoebox, Oil Pressure Sending Unit part#??
Old Aug 20, 2003 | 10:45 PM
ponyackn's Avatar
Question Shoebox, Oil Pressure Sending Unit part#??
Hi,
Shoebox, if you're out there, could you please provide me with a part number and possible place to buy the part.
I'm in need of the connection that plugs into the oil pressure sending unit on my '96 TA. I found that my connection no longer has the wire connected to it. Since I am having my tranny pulled next week, I'll be able to install it.
Actually, if anybody knows where this wire leads to, that would be great because I haven't any idea.
Thank you,
Daniel
Old Aug 20, 2003 | 11:15 PM
The connector for the oil pressure switch (sensor) is GM PART # 12085499 and is ACDelco #PT121.
The wire goes to the gauge on the cluster.
Did you need the sensor # too? GM PART # 10201491
Get all your GM parts from Jason or Dal.
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Old Aug 20, 2003 | 11:38 PM
ponyackn's Avatar
Thumbs up
I hope you can accept yet another thank you from yet another board member
Daniel
Old Sep 6, 2003 | 08:11 PM
ponyackn's Avatar
[QUOTE]Originally posted by shoebox
[B]The connector for the oil pressure switch (sensor) is GM PART # 12085499 and is ACDelco #PT121.
Shoebox,
Where do I feed the wire? Does it go thru a spot in the firewall to the gauge cluster?
Thanks,
Daniel
Old Sep 6, 2003 | 08:32 PM
[QUOTE]Originally posted by ponyackn
[B]
Shoebox,
Thanks,
Daniel
It goes into the main engine harness on a tan wire and passes under the pcm through the large grommet in the firewall. It goes through C220 in cavity "B" (ignore the keyless receiver that you don't have on your 1996). Then on to the cluster connector on cavity "B16" for the Pontiac.
Old Sep 6, 2003 | 10:21 PM
ponyackn's Avatar
Smile
We now have oil pressure reading
The key words you gave me were "tan wire". That was more info given than I could imagine
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
