Cam installed and the car won't start!!
Old Oct 26, 2007 | 04:51 PM
kochisp's Avatar
Please help....I just installed a cam in my 95 z28 and all the car will do is turn over and backfire occationally out of the intake.
I replaced the other cam with the exact same cam. (224 236 Comp Cam)
The reason for the replacement was because a lifter turned sideways on me and it ground the lobe off the cam. When I installed the new cam I used the instructions on Shoebox's website as a reference. Although since I wasn't changing the timing set I put nail polish on the chain and both sprockets to line them up. I also marked the block with nail polish to set the new cam in the exact same place. I know I put the right hole on the opti on the cam dowel. I was thinking maybe it could be the rocker arms, but wouldn't it at least start? Or try to start?
Old Oct 26, 2007 | 07:31 PM
kochisp's Avatar
I also tried firing some starting fluid in the intake to see if it would fire at all, but I got nothing.
Old Oct 26, 2007 | 08:32 PM
ricehammer's Avatar
Sounds like timing. Check your plug wires and make sure they are hooked up correctly. If that isn't it, you may have put the timing chain back on a tooth off. You can check this without pulling the timing cover (oil pan - you know the pain), but you'll have to pull the water pump, opti and crank pulley. Use a 7/16"-20 bolt and nut to lock the bolt to the crank. Rotate the crank with a wrench on the locking nut until the cam dowel is at 3 o'clock. You may have to pull plugs to get the engine to turn easily. Next check the position of the crank key. It should be at 1:15. BTW - the stock/aftermarket timing sets have dots that are used for indexing the cam.
Just a couple of ideas, maybe someone else will chime in with some others .
Old Oct 26, 2007 | 08:37 PM
dangalla's Avatar
check your plug wires very good, very good
if that is not the problem you must have timed it incorrectly like stated above.
Old Oct 26, 2007 | 10:00 PM
kochisp's Avatar
That is great feedback thank you!!!
Tomorrow I am going to tear into it and figure it out one way or the other
I just don't get how it would be off if I marked the chain and the sprockets with nail polish and put them back the same way.
And as far as the plug wires, wouldn't I still at least get the engine to fire a little bit if a couple were off? I even sprayed starting fluid into the intake and couldn't get so much as a tease of ignition.
Thanks guys!!
Old Oct 27, 2007 | 12:01 PM
Are you 100% certain that you put the cam dowel pin in the correct hole on the Opti?
Old Oct 27, 2007 | 12:11 PM
kochisp's Avatar
I would say I was 100%.....but at this point I am not sure of anything
I am going to pull the opti off and see what it looks like.
Thanks so much for the help!!!
Old Oct 27, 2007 | 02:28 PM
kochisp's Avatar
Ok....I pulled the opti and the dowel pin was in the right spot, I also set the cam dowel pin to 3 o'clock and the key hole on the crank is at 1:15.
I don't know what to do now.....
Any thoughts on what to check?
Old Oct 27, 2007 | 02:45 PM
kochisp's Avatar
Also, I was looking at the diagram on shoebox's website and I am concerned about determining if the timing is right based on the dowel pin at 3 and the crank key at 1:15. According to the diagram the crank key is in that position at both #1 and #6 TDC. I am going to try to figure out if it is at #1 TDC or #6.
Old Oct 27, 2007 | 09:10 PM
dangalla's Avatar
just install it dot to dot. crank dot at twelve and cam at six and you will be at 6 tdc
LeftoverChinese
Jan 14, 2024 03:03 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
