Cam install & TDC Question
Old May 17, 2009 | 04:56 PM
lightskindwonder's Avatar
First off...let me apologize for redundancy....I just want to be absolutely clear...
When I go to put my new cam in, I can assume correct alignment & #1 TDC when I rotate the cam & crank so that both the cam sprocket and crank sprocket holes line up (i.e. crank hole is at 12 o'clock and the cam hole is at 6 o'clock) correct?
Old May 17, 2009 | 05:14 PM
ACE1252's Avatar
For proper timing, assuming the cam is manufactured correctly, the only thing you need to worry about is lining up the dots on crank sprocket and cam sprocket. Crank sprocket dot at 12 o'clock and cam sprocket dot at 6 o'clock. As shown here....lower right diagram.
http://shbox.com/ci/sprockets.jpg
More explanation is here....
http://shbox.com/ci/cam_install.html
mel0n666's Avatar
is this what your looking for?
http://shbox.com/1/4th_gen_tech2.html#cam_timing
Old May 17, 2009 | 05:55 PM
Nope, that would be #6 TDC, but that is where you want it.
Old May 17, 2009 | 07:21 PM
so then both timing gear dots @ 12 o'clock would be #1 tdc? The reason I ask is because i plan on changing out the springs & adjusting the rockers cylinder by cylinder, in the firing sequence, to avoid confusion.
Old May 17, 2009 | 10:08 PM
ACE1252's Avatar
Yes, both dots will be 12 o'clock for 1 to be TDC. For rocker adjustment, I didn't even look at the timing set....I just watched the lifter movement.
Old May 17, 2009 | 10:21 PM
Yes. If you click on the cam timing animation link from my site posted above, you will see the relationship for all cylinders.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
