Cam install gone wrong
Old May 3, 2006 | 09:08 PM
1993z28camaro's Avatar
So I went to see the car tonight in the shop and the mechanic said that compcams should of sent me guide plates. The 1.6rr are slipping off the pushrods and when adjusted them he said that they slipped right off by hand. So does anyone know the part # for the guide plates I need.
Old May 3, 2006 | 09:10 PM
jerminator96's Avatar
Re: Cam install gone wrong
Check the Classifieds on here, I know I have seen a set for sale.
Old May 3, 2006 | 09:31 PM
Thanks but I need them tomorrow so it can be done and I don't have to drive this truck w/the horrible blue oval on the front any more.
Old May 3, 2006 | 09:45 PM
Javier97Z28's Avatar
Moderator
#14011051 not sure you'll be able to get those at any dealer right away.. most don't carry them in stock afaik.
Old May 3, 2006 | 09:53 PM
What about jegs?
Old May 3, 2006 | 10:04 PM
Daniel6718's Avatar
get them from the local chevy dealership..if need be go to 2 dealerships...and most dealerships will send them to eachother, youll have them tomaro if you want
Old May 3, 2006 | 10:22 PM
So go with the gm ones not aftermarket?
Old May 3, 2006 | 10:25 PM
Moderator
There are no aftermarket guideplates that keep the proper LT1 valvetrain geometry... they all angle the rockers some.
Old May 3, 2006 | 10:37 PM
Use the GM ones mentioned or adjustable guideplates. SBC plates will not correctly align the LT1 pushrods.
Old May 3, 2006 | 11:00 PM
HardcoreRM125's Avatar
The only ones that will work besides the GM ones are adjustable ones such as ISKY's AGP's ...
Old May 4, 2006 | 12:00 AM
Z95m6's Avatar
Anyone else have a problem with the GM guide plates rubbing the pushrod. On 2 motors i've worked on the pushrods have lightly contacted or were within a hair of rubbing the bottom of the guide plate. I took them out and ground the bottom of the opening down to make sure i had plenty of clearance. Anyone else have this happen?
Old May 4, 2006 | 04:42 AM
MeanGreen97Z's Avatar
Ya it is a common problem. Grinding them is a common fix also.
Old May 4, 2006 | 05:56 AM
30AnvZ28's Avatar
Grind the guideplates. I paid like $26 for new ones from thunder racing if I recall. Worked fine.
Amshnock
14
Jan 18, 2015 11:47 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
